"Body control module..."
Old Jan 21, 2014 | 08:02 PM
BurgXK8's Avatar
Default "Body control module..."
ok, what is it and what does it cost?
Got a slow drain on the battery that might involve replacing this part. Thoughts?
Old Jan 21, 2014 | 08:09 PM
WhiteXKR's Avatar
Check that the tiny door in the front of the ignition key slot is not sticking open. This often prevents several computer modules from going to sleep.
The BCM is a computer module that control dozens of different functions. If you really need to replace it, get a used one with a matching part number and VCATs code, but a lot of things besides the BCM can cause a battery drain.
Old Jan 21, 2014 | 08:25 PM
test point's Avatar
Originally Posted by WhiteXKR
but a lot of thing besides the BCM can cause a battery drain.
. . . lots and lots of things.
The security system at the top of the list. The 'sleep' mode battery drain should be less than 30ma. The sleep mode should occur 2 - 3 minutes after everything is shut down . . . with the key removed. Still have more drain . . . lock the car which should immediately put it into sleep mode.
Old Jan 22, 2014 | 02:27 AM
JagV8's Avatar
Grab JTIS and it has more info including electrical guide.
Old Jan 22, 2014 | 09:46 AM
BurgXK8's Avatar
Thanks - I tried leaving it locked for over five days and it still died. Did not notice the 'little door' by the ignition switch but will inspect that next.
Old Jan 23, 2014 | 12:24 PM
oldmots's Avatar
Check for drain by putting your voltmeter turned to amps between the battery and the battery cable positive. Pull out the trunk light bulb and then watch the meter. The drain should be less than 50 milliamps with nothing running. If you have more, start pulling fuses until the rate drops to less than 50 ma. The last circuit you pulled has the drain.
Old Jan 25, 2014 | 10:05 AM
BurgXK8's Avatar
Hey, thanks for that - going to send that tip over to the shop since they still have it. ...then again, if they don't know this by now, I need to find a different shop!
Old Jan 30, 2014 | 05:52 PM
BurgXK8's Avatar
Question Oh Boy....
I just got the estimate from the shop. They've disconnected everything possible and narrowed it down to the body control module itself. Diagnostically I'm already up to over $600 in time spent to do this - I saw what went into that and I don't doubt it was a lot of work.
To complete the job will set it up to over $2k! If I'm reading their estimate right, the BCM itself costs about $1100.
The only problem I'm experiencing with this car is a battery that dies if left unattended for a few days. Trying to decide if that's worth the trouble to replace the BCM and if there are any other reasons to do so aside from fixing this one annoyance. If the BCM is bad in this sense, could it be bad in other ways that may manifest themselves later?
Old Jan 30, 2014 | 06:31 PM
check around - BCM can be found for about 800 if not less - call Terry's Jaguar parts or check SNG Barratt (sponsor) - SNG shows one for $665 then would need programmed. Trust me - shop around - had my local dealer (before I found the forum) try to tell me I needed the BPM - $1200 for the part plus 550 labor. Did find it cheaper but luckily I ended up having an issue that was other than the BPM
Old Jan 30, 2014 | 08:36 PM
BurgXK8's Avatar
Thanks, I will do just that. SNG Barrett is right down the street from me in Manchester NH. So you think it's worth replacing?
Old Jan 31, 2014 | 07:22 AM
ArtyH's Avatar
You could just disconnect the battery on one terminal when you know you are not going to use it for a few days. Taking into account insurance issues of course, it could buy you time until an affordable BCM becomes available. Are there no refurb services available for this part in the U.S? I know there are some places recommended on this site which refurb some of the modules, but not sure about this one. Its usually a bad connection or a failed diode/resister, after all they are getting a bit long in the tooth now and part are due to fail because of old age.......
Old Jan 31, 2014 | 08:23 AM
BurgXK8's Avatar
Just tried Tom's but they don't have the exact part and VIN number is critical with these, as one would expect. Yes, I could wait till one comes available but it's a lot of labor to get this far so might as well get the job done.
After talking to SNG, their price is about what the shop is charging, slightly more ($1500). They say the units need to be exact for the car and an unprogrammed unit would need to have the latest/correct software from the Jaguar dealer, which is why they're expensive. They don't even take these things as cores, they just toss the old ones. So though I might be able to find the fault with the old unit, it's not clear that anyone refurbs them or does so correctly.
I'm not keen on installing a used one that might work only to have it mess up something else electrical. Has anyone tried a swap here?
Old Jun 9, 2024 | 07:30 AM
Harrison ohene's Avatar
Default Bcm
Hi to and happy Sunday to all ,I am working on 2011 jaguar xjl 5.0 V8 , the body control unit is giving me an issues the BCM goes off completely after the car go sleep or I disconnect the battery, but if I disconnect the BCM power socket for 5 to 10 minutes and reconnect it then the key can be operated , should i go ahead and do new bcm install program? Or I am doing something wrong? Thank for any help
Old Jun 9, 2024 | 10:31 AM
michaelh's Avatar
Originally Posted by Harrison ohene
Hi to and happy Sunday to all ,I am working on 2011 jaguar xjl 5.0 V8...
Hi Harrison,
You're in the forum for the older X100 XKs. Post your question here:
https://www.jaguarforums.com/forum/xk-xkr-x150-33/
...and the good folks in the X150 forum will help you.
H20boy
Dec 24, 2024 03:23 PM
xjrjag
Oct 24, 2024 03:09 PM
bamforp
Aug 14, 2024 05:36 PM
Lannyl81
Sep 19, 2015 08:07 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
