Bolt Size for Engine lifting/removal Points 4.0L
Old Apr 7, 2014 | 04:19 PM
CharliePar's Avatar
Default Bolt Size for Engine lifting/removal Points 4.0L
Hi,
Could anyone tell me the size of the threaded bolt holes at the firewall/back side of the cylinder heads on a 4.0L XKR engine '96 - '01?
Those are the holes used for attaching the lifting eyes for engine removal.
They appear to be 14mm, but I cannot tell the thread pitch.
Thank you.
Charlie
Old Apr 8, 2014 | 08:40 AM
lgm's Avatar
lgm
Not sure about the bolt size, (have not gotten that far yet) but i need to fabricate the engine support braces. Did you make those or buy them somewhere!
Old Apr 8, 2014 | 09:07 AM
dsnyder586's Avatar
If you want to go hillbilly style, just use hooks on the catalytic converter outlets.
Do so at your own risk, however it will work.
Old Apr 9, 2014 | 08:53 AM
CharliePar's Avatar
Thanks for your ideas. I have been able to determine the bolt size after some trial and error.
For future reference, they are 14mm x 1.5mm pitch. Length of the bolts can be up to about 30mm.
I am planning to use chains between the bolts and then attach those to the tilting device on the engine hoist.
Old Apr 9, 2014 | 02:23 PM
XKRacer's Avatar
I must admit I wrap a strap around the cats and use the eyes at the front
Old Feb 7, 2016 | 04:16 AM
nurquhar's Avatar
The sump plug bolt will fit, its M14x1.5. Save your old ones. Glad I did.
D.K
Dec 10, 2023 02:05 AM
kelliott
May 31, 2022 05:26 PM
philwarner
Sep 5, 2015 10:05 AM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
