Can Anyone tell me how bad these are?
Old May 19, 2011 | 03:50 PM
zmann96's Avatar
Default Can Anyone tell me how bad these are?
A few weeks ago when I was replacing the coil,I decide to check to see if my tensioners had been replaced from the previous owner. They weren't so I ordered some and did them today. They were both cracked but not sure how close it was before they let go. The one on the right bank was the worst. If anyone has any experience in this area would like to know how long before it was toast if I hadn't changed them. Thanks
There should be an attachment.
Attached Thumbnails Can Anyone tell me how bad these are?-jag-timing-chain-tensioners-003.jpg
Old May 19, 2011 | 04:01 PM
XKRacer's Avatar
As soon as cracks appear, it could literally of been any time, you did good!
Old May 19, 2011 | 04:44 PM
plums's Avatar
Just be happy that you got around to replacing them before they let go.
How many miles on that set?
Old May 19, 2011 | 05:02 PM
zmann96's Avatar
54,234 miles
Old May 19, 2011 | 05:24 PM
Felipe Pr's Avatar
You were lucky man. I have a 97 xk8 bought in sept 2010 with 31.5K miles. As soon as I got it, I changed the upper tensioners (they were OK), the shock mounts, front and rear (they were pretty bad), and the thermostat. Didn't want to take the risk as it can cost an engine.
Old May 19, 2011 | 06:40 PM
Paul Pavlik's Avatar
Stage 1: Original Tensioners when New.
Stage 2: Original Tensioners, now Cracked.
Stage 3: This:
Attached Thumbnails Can Anyone tell me how bad these are?-jagtimechain12.jpg
Old May 19, 2011 | 06:44 PM
Gus's Avatar
Gus
Your timing was right!
Old May 19, 2011 | 06:47 PM
plums's Avatar
Stage 3: This:
Your post might need fixing, because the wording seems fudged up due to the attachment
edit: ok the edits crossed each other.
Old May 19, 2011 | 07:17 PM
zmann96's Avatar
I heard that when you start the car ,if you had the plastic tensioners you would hear a noise.When I got it about 8 months ago it sounded OK so I just assumed ( I know, assume nothing) it was already done. I've been chasing bad coils and the RP coding since I got the car.When changing,swaping and replacing coils I noticed my gaskets were gone on the covers so I ordered the gaskets and changed one about two weeks ago, when I took the cover off low and behold I saw I had the plastics ones so I ordered the new ones and changed them today. From what everyone has been saying,I guess I lucked out. Thanks guys.
Old May 20, 2011 | 01:11 PM
pophen's Avatar
ZMANN96, Hop in the car and visit Atlantic City. You've got the force with you. Jack
Old May 20, 2011 | 04:39 PM
zmann96's Avatar
I know....... I dodged a bullet on that one from what I've heard.
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
MrWhite
19
Jun 14, 2022 07:49 PM
hoodun
May 15, 2019 09:31 PM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
workworkwork
Oct 1, 2015 01:44 AM
