can headlight washers be aimed
Old Mar 25, 2018 | 02:44 PM
05XK8cfe's Avatar
Default can headlight washers be aimed
Is there a process for aiming the headlight washers? My hood and anything nearby gets soaked when I use them.
Old Mar 25, 2018 | 04:55 PM
CorStevens's Avatar
no but they can be disabled. in the fuse box by the ABS pump on the left side forward of the shock tower remove their fuse. forgot which one.
Old Mar 25, 2018 | 08:22 PM
Johnken's Avatar
Or you can pull the relay, I did after it shot a passenger in the eye. Ask if you want me to post photo of relay location.
Thanks John
Old Mar 26, 2018 | 02:57 AM
There's NO adjustment but cleaning the nozzles can improve spray pattern.
The jet assembly is secured with a clip (arrowed)
Old Mar 26, 2018 | 05:49 PM
SeismicGuy's Avatar
Wouldn't it be great if you could aim the washers at idiot drivers?
Doug
Old Mar 26, 2018 | 05:51 PM
SeismicGuy's Avatar
By the way, when I was diddling around having to replace the power wash unit due to that front plastic nozzle piece not properly holding the shiny trim piece, I had wondered if it was possible to source that plastic nozzle somewhere. This would have saved the hassle of replacing the whole stinking assembly.
Doug
Old Mar 27, 2018 | 07:44 AM
reb1999's Avatar
Do these washers actually do anything. Never tried them. Seems useless without a wiper of sorts. I think it would be easier to follow a tractor trailer truck for a few miles on a rainy day.
Old Mar 27, 2018 | 11:20 AM
flydutch's Avatar
Pulled the fuse on mine - never think about them again. Don't need them down south in any case...
Old Mar 27, 2018 | 02:30 PM
Jandreu's Avatar
Mine do a better job of spraying the winsheild than the wiper washers do!
Last time I had my state inspection done the guy had me turn headlights on to check them first, left them on then hit the wipers. Sprayed the tech in the face!
Old Mar 27, 2018 | 02:56 PM
Originally Posted by reb1999
Do these washers actually do anything. .....
I've always thought they are completely useless, only included because other prestige vehicle manufacturers fit them and the Jaguar presumption is that buyers expect them in the list of toys.
However, I'm obsessive with my cars and if something is fitted, it must work properly so fuse pulling or other disabling techniques is not for me.
Old Mar 27, 2018 | 05:14 PM
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
Hmmm, mine must be a fluke as they actually work well to remove the dust/road film.
Old Apr 1, 2018 | 08:10 PM
Wide_Tyres_2's Avatar
Living on the "wet coast" of Canada I find them real helpful to clear the road film and keep them bright.
IMHO... the best road film remover is made in Comox BC .... North Vancouver Island ...called CV9 ...sold in of all places the local Winsor Plywood lumber store.
Ive used it for over 30 years and I just cuts road film ....period
Cheers,
Andy
Old Apr 1, 2018 | 10:53 PM
SeismicGuy's Avatar
I'm kind of the same way. In California I never need or intend to use these but was impressed that such a gizmo came on the car. Still I do want them to be operable. Amazing that Jaguar would have included something like this but did NOT include a low tire pressure sensor.
Doug
Old Apr 2, 2018 | 06:18 AM
CorStevens's Avatar
Doug
TPMS was rather new, probably non-existent, when our cars were designed. it is surprising that this was not added when the cars received the major tech update of 2003.
there are some very nice add on systems out there. the one that i installed works very well and is a lot cheaper and easier to replace than one of the factory internal sensors in other cars. the aftermarket units provide almost real-time data which is nice for adjusting performance and finding slow leaks before they become an inconvenience. the units are very precise and one can have a nice OCD time with the pressures
the unit that i purchased is not longer available, however similar solutions exist. the wheel air-stem sensors use replaceable batteries and the head unit is solar.
Amazon Amazon
Old Apr 2, 2018 | 07:40 AM
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Surprised me too that they weren't on our vehicles as my 89 Corvette had them as a factory option (extra $345.00) and they were standard equipment from 91 on.
Old Apr 2, 2018 | 10:04 AM
SeismicGuy's Avatar
I had a 95 Corvette and the LTPWS was not standard except (I think) if you bought the run-flat tires. In any case the technology was clearly there in the early 1990s. Our cars were at least $75K and the real PITA was if you got the $6K premium wheel option with the BBS wheels. Since checking air in these is a real chore due to the special screw on stem, you would have thought that the extra $6K would have included a pressure monitoring system.
Doug
Old Apr 4, 2018 | 06:49 AM
Doug
You're correct. The tmps was standard on the 91 ZR1 package, optional on the others, standard in 97.
And with the hidden headlights, don't know how they would have put a headlamp washing system on it.
Old Apr 4, 2018 | 02:08 PM
SeismicGuy's Avatar
Yeah--I miss the rotating headlights.
Doug
Old Apr 10, 2018 | 03:20 PM
melhookv12's Avatar
Legal requirement here in the UK with Xenon lamps.
You can adjust the ones on my S Type.
CDSsilver
Mar 6, 2023 03:37 PM
flyrr100
Nov 17, 2012 04:35 PM
squish
Oct 6, 2010 12:57 PM
Fraser Mitchell
Sep 3, 2010 10:30 AM
canman
May 31, 2009 04:47 PM
