can't clear ECM
can't clear ECM, the engine in my 99 XKR shot craps, replaced engine. will start and die ,have codes for upstream oxy sensors bank 1 &2, crank sensor( put in new one) my scanner want clear codes on this car. will on all my others., left battery out all night ,hoping to clear codes like on most cars and codes still there, anybody have any ideas
If it STARTS then DIES, you are likely to have a fuel feed issue. A subset of DTC's intentionally have the effect of putting the vehicle into "reduced performance" or "limp home" mode but the engine will usually continue to run in these circumstances.
You have fitted a matching engine sourced from a 99 XKR and not a later iteration of the V8?
Odd that a scanner won't clear codes as even the most basic normally do this. Perhaps Jaguar SDD is going to be required to troubleshoot this.
The XKR was introduced in the US for MY 2000. Possibly your car was manufactured in 1999 but the US considers it a 2000MY. (AJ27)
The XJR engines 1998 and 1999 are AJ26 and are not 'Plug & Play'. (many differences)
If you needed a replacement engine, your car requires an AJ27 from a 2000 to 2002 XKR or a 2000 to 2003 XJR 4.0.
The AJ26 will require many 'modifications' to work in your car.
they said it came from a 99 xjr but now will have double ck. wonder why codes want clear with battery undone like most cars , haven't started it and codes still there, thanks you guys for the help
thanks motorcarman they said it came out of 99 xjr, think i'm screwed., thought they were the same have old motor can i change parts
The O2 sensors shouldn't stop the car running, while the crank sensor will. I would worry about the good-ness of the new crank sensor of course, but not the code clearing so much. I'm sure you want to be able to read NEW codes tho, as you progress...
Dude, if ya ended up getting sold a not as described engine, I'm sorry to hear that. That's a real bummer. Damn suppliers!
The CKPS segments on the torque converter drive plate and CMPS reluctor count on the intake cam(s) are DIFFERENT.
This AJ26/AJ27 swap and difference has been discussed REPEATEDLY on this forum.
You will get faults logged if you try to run a different engine in a car with an ECM properly configured to THAT CAR. (usually CKPS/CMPS relationship)
The AJ26 engine will not work in the AJ27 car (and vise versa) without many swaps/modifications.
