Can't get Serp. belt back on
Old Nov 30, 2013 | 08:22 AM
dhferry1's Avatar
Default Can't get Serp. belt back on
Guys,
i had to replace my alternator last week, which was a blast! But now I can't get the serpentine belt back on? I don't know if the new alternator pulley's is bigger or what..... The alternator was purchased at advanced auto parts and it's an ND unit, like the original 1 that failed....
Thanks for any info. ideas
Dean
Old Nov 30, 2013 | 08:37 AM
jimbov8's Avatar
Hi Dean,
Not trying to teach your Granny to suck eggs but, have you made sure the belt is fitted correctly and did you slacken the tensioner when refitting the belt.
Just a thought.
Old Nov 30, 2013 | 10:08 AM
mike66's Avatar
I found I had to slip the belt on the pully without a lip - either the tensioner or idler pully, I forgot which one. Good luck!
Old Nov 30, 2013 | 10:21 AM
platinummaker's Avatar
+1 per Mike66. Only way I could get new belt on
Old Nov 30, 2013 | 11:06 AM
dhferry1's Avatar
Guys,
Thanks for the rapid replies, and I should of stated that it's a 97' just in case it makes a difference. It's fitted properly, and only pulley that I have that doesn't have a lip on it is the tensioner pulley? And this is also the old belt, not a new 1.
Thanks,
Dean
Old Nov 30, 2013 | 11:09 AM
Jochem00's Avatar
Just try harder.
I suppose you did not replace the belt and use the existing one? That should be easier than a new belt.
Try some soap on the belt and pulley to get it slide over the pulley easier
Old Nov 30, 2013 | 11:56 AM
dhferry1's Avatar
Originally Posted by Jochem00
Just try harder.
J,
Great idea about the soap. I have been trying too hard, I snapped off the 13mm tensioner bolt last week, (Which you CAN'T buy from Jag or anywhere that I could find) and I had to buy a NEW tensioner pulley! Which I don't want to do again, hence me asking the experts, (You guys! )
Old Nov 30, 2013 | 12:25 PM
dhferry1's Avatar
Just try harder.
J,
BRILLANT, I just soaped her up a little, (Ok alot) and it slippped right on the tensioner! J, you the man!
Thanks guys, now i just got to get her put back together, and then I'm afraid to say, she's going up for sale. Need to make room in the garage....
Thanks again,
Dean
Rivguy
Dec 4, 2020 07:55 AM
Aus V8S
Nov 13, 2015 11:01 AM
Bones
Sep 8, 2015 08:34 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
AL NZ
Sep 4, 2015 08:39 PM
