Can't move gear selector 1997 xk8
Old Feb 26, 2009 | 05:56 PM
lincjag's Avatar
Default Can't move gear selector 1997 xk8
I have been trying to get a 1997 xk8 on the road. I replaced the security module and wiring in the trunk. The car now runs but it will not shift out of park. I have tried jumping connections at the brake pedal switch to see if the switch was bad. It did not seem to help. The brake light has not worked when I applied the brake pedal. I am aware that the security module will need to be reprogrammed. Is this related to the shifting situation? The convertible top is also inoperable. Any help is greatly appreciated.
Old Mar 1, 2009 | 01:37 PM
H20boy's Avatar
Any luck with the car linc? Did you try the key 'unlock' above the gear shift? Did your YM have this?
Razor
Aug 28, 2019 08:34 PM
user 652867429824
Oct 28, 2015 10:18 AM
speacock
Sep 14, 2015 07:57 PM
hen555
Sep 7, 2015 11:13 PM
arnoldmilk
Sep 3, 2015 07:42 PM
