Car wobbles and shakes....
Old Oct 26, 2013 | 02:54 PM
Windycityx's Avatar
Default Car wobbles and shakes....
My 97' XK8 wobbles, shimmies, and shook from the time I bought it, had it looked at by a few mechanics on a lift, both said front passenger wheel bearing.... and everything else seems real solid they both told me.... had it replaced, along with the front driver tire at it was showing un-even wear.... it still does the same thing, sometimes not so bad, sometimes worse, especially noticeable around 50-70mph.
I jacked up the car today and the passenger wheel does have a little give, not much, but it does move slightly when holding the tire with both hands at 9pm and 3pm.... it moved pretty freely....
So I do the other side and it seems solid, no play, but it seems really hard to spin, definitely quite a bit harder then the passenger side, any ideas?
Old Oct 26, 2013 | 06:34 PM
Jag#4's Avatar
Wheel movement as you describe it sounds like bearings and the early models are known for wheel bearing issues. They upgraded bearing size on later models to cure it. However, I think you said the shop changed them.
I would take it back and let them have another look or get a second opinion from an independent Jag shop.
Old Oct 26, 2013 | 06:59 PM
Windycityx's Avatar
I just replaced the passenger side as the driver side seemed solid, any other suggestions before I take it back in?
Old Oct 26, 2013 | 07:19 PM
test point's Avatar
The early cars were subject to significant problems with all of the front end parts. Without getting everything up front right you will eat through tires at an astonishing rate. You will also be amazed at how much better these cars feel with a front suspension/steering as intended by Jaguar.
Old Oct 26, 2013 | 11:31 PM
Windycityx's Avatar
After thinking about it, what could be the reason for the drivers side front wheel not spinning freely?
Old Oct 27, 2013 | 03:56 AM
test point's Avatar
First thought is a stuck brake caliper. Does the 'wobbles, shimmies, and shook' occur all the time or only while braking?
Old Oct 27, 2013 | 04:28 AM
smithtrevor's Avatar
While your at it have a look at the front disc's...if they are a cheap after market make from flea bay the chances are they are warped (i had exactly these symptoms on a Ford V6 Cougar), a dial gauge will show this accurately but it's possible to mock something up using a fixed point at the edge of the disc.
Old Oct 27, 2013 | 08:22 AM
Windycityx's Avatar
Yes at all speeds, and a little different every time I drive it, I am only thinking that it may be something catching after I jacked the car up yesterday and I had to put quite a bit of pressure on the wheel just to get it to spin.
Old Oct 27, 2013 | 03:42 PM
Windycityx's Avatar
So after driving the car today, I went and checked the passenger side, rotor, caliper, and brake pad were warm.
And the drivers side, the wheel that does not spin freely, the rotor was much hotter along with the caliper and brake pad, what do you think all that means?
Old Oct 27, 2013 | 04:33 PM
test point's Avatar
Stuck caliper. See post #6.
Old Oct 27, 2013 | 05:40 PM
Sounds like it.....Take off the wheel, remove the caliper and hang it clear of the disc, put the wheel back on and spin it with your hand, it should run smooth and clean for several rotations. If it does then post #6 is your problem!
Old Oct 28, 2013 | 07:48 AM
aode06's Avatar
while your at it, clean the face of front speed sensors by removing the 8mm bolt that holds them down.And spray a lil oil on the wiring connectors to them.
Old Oct 28, 2013 | 08:02 AM
test point's Avatar
. . . But not by the brake lines!
Old Oct 28, 2013 | 10:33 AM
Windycityx's Avatar
I also forgot to mention it is now throwing up a lot of brake dust on the wheel. And would this also possibly cause an ABS light, traction control and stability control fault codes on dash as well?
Old Oct 28, 2013 | 12:08 PM
mike66's Avatar
See #12. Sounds like new caliper and pads in your future. Change to ceramic while you're at it......way less dust.
Those lights can also be due to module failure if cleaning the sensors doesn't help.
Old Oct 28, 2013 | 12:52 PM
Jag#4's Avatar
Extra brake dust is because they are binding. The dust might cover the wheel sensors and that would throw the code.
Time to get new pads and maybe calipers. If the calipers are bad, better change the rotors while you're at it. If they overheated, warping is possible.
Clean everything you don't replace.
Nati
May 16, 2020 08:30 AM
rvdz
Dec 7, 2019 06:42 AM
Jandreu
Aug 29, 2015 07:31 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
