.....................carbon dynamic air induction jaguar xkr
Old Jan 14, 2013 | 04:24 AM
User 070620's Avatar
Default .....................carbon dynamic air induction jaguar xkr
this is what i want for my XKR!
Attached Thumbnails .....................carbon dynamic air induction jaguar xkr-engine-large.jpg
Old Jan 14, 2013 | 05:23 AM
steveinfrance's Avatar
I presume you are joking?
Old Jan 14, 2013 | 05:25 AM
avos's Avatar
Difficult to fit on a steel bodied XKR, this is from a aluminium version where there is more room between the hood en engine (and in front of the engine as well...).
Old Jan 14, 2013 | 05:39 AM
avos's Avatar
Attached was the precurser ;-)
Attached Thumbnails .....................carbon dynamic air induction jaguar xkr-img_0050.jpg
Old Jan 14, 2013 | 07:48 AM
ccfulton's Avatar
I have to ask, does it really offer much benefit? Or was it one of those see if you could sort of projects?
Old Jan 14, 2013 | 07:50 AM
xenophobe's Avatar
Still waiting for more info about the 90mm carbon intake...
Old Jan 14, 2013 | 08:12 AM
I was not totally kidding! I know that the pictures are in the XKR with aluminum frame, but it could be a good idea to make a similar filter in carbon and have a bonnet cut to create the space needed, making a air dynamic as this....
Attached Thumbnails .....................carbon dynamic air induction jaguar xkr-tuned-corvette-supercharger.jpg
Old Jan 14, 2013 | 09:05 AM
avos's Avatar
The setup as I have it is more than sufficient for what it has to do (so with the cone filter under the headlight in the bumper), so this is not something I would be interested in.
Maybe they choose this way as easiest setup, and there is probably also some ram air openings in the bumper, but that just as well can be done with the single air tube on the steel bodied cars.
Old Jan 14, 2013 | 09:23 AM
avos's Avatar
I was hoping to see one this month, but as it looks now, it may be next month (not under my control...).
In case someone wants to know what it’s about, see the attachment. This one is made by TLJaguar in the UK especially for the twin-screw kit, and they can be reproduced.
Attached Thumbnails .....................carbon dynamic air induction jaguar xkr-img_1033.jpg
Old Jan 14, 2013 | 04:43 PM
XKRacer's Avatar
I have been asked to do this a couple of times.... Let alone the space issue you have the MAF problem.... A twin intake requires twin MAFs.... It is just not feasible..... The gains would be negligible
Old Jan 14, 2013 | 08:19 PM
The Coupe's Avatar
Avos, do you have any photos of your intake system you would be willing to share?
Old Jan 14, 2013 | 10:23 PM
avos's Avatar
You can already see the path in the picture shown with the carbon intake pipe, here is another:
Attached Thumbnails .....................carbon dynamic air induction jaguar xkr-intake.jpg
Old Jan 15, 2013 | 03:46 AM
the question I posed is that normally the suction tube passes over the exhaust manifolds by heating the inlet air to the engine. In addition, with a central air intake dynamic, we have a natural extra pressure in the compressor with the increase of speed.
is for this reason that the jaguar racing Ferlito using dynamic central air vents for their race s-type and XF cars!
I think there is a reason!
Attached Thumbnails .....................carbon dynamic air induction jaguar xkr-racing-jaguar-r-engine-compartment.jpg   .....................carbon dynamic air induction jaguar xkr-racing-jaguar-r-engine-supercharged.jpg
Old Jan 15, 2013 | 04:37 AM
XKRacer's Avatar
This is my 90mm induction set up.... still needs dressing and a good polish but you get the idea..... I have had to remove a small piece of the bonnet/hood frame for clearance, nothing drastic
I am designing a special type of cold air feed using liquid CO2, this runs at -80 and the air passes over it should cool down alot.... in theory 20BHP gains maybe possible but we shall see the good thing is it will work on XK8s as well as Rs
You do need to fit some good shielding to protect the pipe from the manifold and cat giving off heat but that is not difficult...
Attached Thumbnails .....................carbon dynamic air induction jaguar xkr-induct2.jpg   .....................carbon dynamic air induction jaguar xkr-induct1.jpg
Old Jan 15, 2013 | 11:44 AM
avos's Avatar
It’s one of the reasons I keep much silicon piping (support by an inner aluminum pipe) instead of aluminum as it gives a little extra isolation.
However I personally think the gains of isolating the tube are very little(/neglectable), at full throttle for a stock car (with a 85mm id intake tube) the air is moving (if my calculations are right) at about 45 meter per second, so not much time for the air to pick up some radiated heat.
Also it’s only when you are standing still you get excessive heat form the manifolds/cats that heats up the piping, but much less when moving.
Old Jan 31, 2013 | 01:48 PM
WaterDragon's Avatar
liquid helium is -452 F / -269 C
simpler, NOS is -126 F
Just FYI
Old Jan 31, 2013 | 02:24 PM
RSsteveH's Avatar
I've got Carbon Dynamic Cold Air Induction in mine - not sure what effect it has but its there. I'm trying to get time to take pics to put up. Not easy though.
Old Jan 31, 2013 | 11:55 PM
avos's Avatar
So what about a de-icer system ;-)
BrentGardner
29
Dec 16, 2024 12:13 AM
Griffbritgreen
Jul 27, 2016 05:43 AM
Series1fan
Sep 5, 2015 08:02 AM
reedmtn
Aug 31, 2015 12:48 PM
divingmom
Aug 25, 2015 07:54 PM
