The cat is out !
Old May 4, 2019 | 03:38 PM
Barry_Tucker's Avatar
Default The cat is out !
Started the first turn after almost 5 months of winter hibernation. Runs perfectly Over the winter I installed new Welsh poly upper shock mounts and new lower shock bushings; new hand brake shoes ( $16 from Rock Auto !! ) and new rear pads. While doing this I noticed the LHS handbrake cable was fraying a bit so I replaced it. Absolutely ZERO coolant loss since I replaced the octopus and header tank last yer so I decided not to do the valley hoses for now. I do LOVE this car
Old May 4, 2019 | 03:54 PM
ccfulton's Avatar
Here's to a good driving season!
Old May 4, 2019 | 08:28 PM
DavidYau's Avatar
Default Another Cat prowls the street
Glad to hear that your X100 is out of hibernation, and all is well.
Time to get some miles in, heads turns, and your grin back.
Old May 4, 2019 | 09:09 PM
Ltd's Avatar
Ltd
Default Another prowling cat
98 X100
Just letting her cool down to avoid heat soak. Kitty is purring
First good run today after a winter of fixing. Both tensioners, transgo mod. Filter changes, fluids. Front wheel bearings, upper shock mounts front and back. Cooling hoses, including octopus, valley. Brake discs, pads. Rear shockers. Sway bar links.
But flawless. Better handling than my previous 94 XJS. Great power, stopping, excellent handling.
My expectations have been exceeded. Thanks Gus, Reverend Sam and countless others.
Old May 4, 2019 | 09:18 PM
AJ16er's Avatar
Wonderful looking car. What wax do you use?
Old May 4, 2019 | 09:25 PM
Ltd's Avatar
Ltd
Maguiars NXT Generation Tech wax.
Thank you. The car had badly swirled paint due to automatic car washes, I assume. Looks great now Grin !
Old May 4, 2019 | 09:28 PM
AJ16er's Avatar
I am brand loyal to Zymol but that certainly is impressive. Swirl marks are usually caused by not clay barring a finish before waxing. Then you're just rubbing the surface contaminants into the clearcoat.
Old May 5, 2019 | 06:09 AM
Jon89's Avatar
Barry,
How much effort was involved in replacing your frayed handbrake cable? And where were the frayed spots located?
Glad to hear that your car is in top shape now....
Old May 5, 2019 | 02:44 PM
Ltd's Avatar
Ltd
The steps I took to achieve this marvelous finish:
wash
clay bar- Maguiars and Mothers
Maguiars 105 cutting compound
maguiars 205 polish
2 coats NXT tech wax Maguiars
i used a DA for cutting and polishing
I am just super thrilled with the Sapphire Blue Mettalic color, really shines through now.
ltd
Old May 6, 2019 | 07:27 AM
@Jon89 If you have the hand brake shoes off the car the cable is not hard to replace. Mine was getting corroded/ frayed at the hub where the cable enters. A previous repair ( not mine ) had not properly replaced the plastic clip which holds the cable to the back of the hub and moisture had got in. The worst bit is getting the brake shoes on an off. the rest is easy.
Old May 6, 2019 | 09:24 AM
Jon89's Avatar
Thanks for the tips, Barry. I will check the condition of my wife's 2006 XK8's handbrake cable when I do the 120,000-mile service later this year....
Lizard Kitteh
Jul 28, 2012 06:38 PM
tomcaticus
May 21, 2011 06:11 AM
Jagman99R
Sep 28, 2010 02:59 PM
alabamabill
Nov 27, 2008 11:57 AM
