cd changer won't recognize disks are installed
Old Jul 31, 2013 | 06:56 PM
Jazz Cat's Avatar
Default cd changer won't recognize disks are installed
01 XK8 convertible, premium Alpine system. Installed magazine for the first time (since my ownership) and changer fails to recognize there are disks in the magazine,
Any common cure ? Suggestions ?
Old Jul 31, 2013 | 06:58 PM
this is fairly common - there is a worm gear in the changer that becomes misaligned - remove the changer, open it up, realign the gear and reinstall - check the following thread
https://www.jaguarforums.com/forum/x...k-stuck-46943/
Old Jul 31, 2013 | 07:35 PM
here is another link for the cd changer repair that will help
https://blogs.oracle.com/miko/entry/cd_changer_repair
Old Jul 31, 2013 | 07:57 PM
Dr. D's Avatar
Howdy Folks:
This has happened to me twice.
The first time I checked the worm which was properly engaged, but rotated it and also the laser arm mechanism so that neither were at the end of travel. Then put it back together and it it worked for about 5 months.
The second time, I did the same thing to repair except that I also read that a dirty laser reader would not "see" the disk and thus would report that there was no disk even if there actually was one loaded. So I cleaned the reader with a Q Tip wetted with some windex. The unit has been working fine for about 3 months. I guess time will tell, but it does make sense to me to clean the reader.
Old Jul 31, 2013 | 11:06 PM
tberg's Avatar
It has happened several times over the past three years. Each time, I just remove the disc carousel and then shove it back in. Always has worked.
Dagny
Jun 11, 2024 01:06 PM
Dz1rfj
Jul 17, 2018 10:29 AM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
Dz1rfj
Sep 16, 2015 03:44 PM
texaspete
Sep 10, 2015 08:34 AM
