Changes for the 98 MY XK8
Old Dec 1, 2019 | 03:40 PM
michaelh's Avatar
Default Changes for the 98 MY XK8
I found these notes in my travels some time ago and then promptly lost them. I can't remember where they came from so I'm unable to properly attibute. They will likely be old news to many, but there are a couple interesting snippets, e.g. they explain why the 97 ECM is unique to that MY
Security System
System Arming/Disarming
A sounder for the security system is installed in production. The tone sounds when locking and unlocking the vehicle. Unlocking the vehicle causes the direction indicators to flash twice and a tone to sound. Locking the vehicle causes the direction indicators to flash once and a tone to sound.
Engine Immobilization
In Canada, Mexico and USA, engine immobilization is introduced. The engine immobilizer ensures the engine can only be started using a valid ignition key.
A key transponder control module (KTCM) installed in the fascia (illustration 9) is linked to the BPM, the ECM and a reader/exciter coil around the ignition switch. The KTCM is programmed to recognize a uniquely coded transponder in the head of each key supplied with the vehicle.
When a key is installed in the ignition switch and turned to position "I" (auxiliary), the KTCM uses the reader/exciter coil to read the transponder code.
When the key is turned to position "II" (ignition), the KTCM exchanges signals with the BPM and ECM and, if the key is valid, fuelling, ignition and cranking functions are enabled to allow the engine to start when the key is turned to position "III" (crank).
If the key is invalid, the fuelling, ignition and cranking functions are inhibited and the engine cannot be started.
Exhaust Camshafts
New exhaust camshafts are introduced to improve engine idle refinement. With the new camshafts, the exhaust valves close 10° earlier, eliminating valve overlap when the intake camshaft is in the retarded position. The exhaust valve lift is reduced to 8.4 mm (from 9 mm).
Spark Plug Gap
As part of the improvement to engine idle refinement, the spark plug gap setting is increased to 1.3 mm (0.051 in). This change applies retroactively to 1997 MY M-V8 should the spark plugs need to be replaced.
Throttle Body
Already introduced as a running change is a new throttle body with additional strengthening webs to reduce internal vibration levels. A further modification at this Model Year introduces an increased diameter securing pin for the throttle position sensor.
EGR SYSTEM
The EGR system was deleted from VIN 011462 during the 1997 MY.
The EGR system has been deleted on NAS XK8 models beginning with VIN 011462. Vehicles with or without EGR can be equipped with the latest ECM part no. LJA *1410CA/*** which replaces LJA 1410AN/***.
***=010 for USA,
***=012 for Canada
ECM
Software changes are introduced to support the revisions to the exhaust camshafts. On NAS vehicles, additional software changes are introduced to operate the leak check of the fuel tank and evaporative loss system. As a result, the 1998 ECM cannot be installed in a 1997 MY XK8
Old Dec 2, 2019 | 01:30 PM
A synopsis of changes up to 2001 MY is given in Jaguar XK8 and XKR by John Blunsden (ISBN 1899870 53 9).
Chapter 7
Improving the product - Running changes and upgrades
jmfowler
Jul 26, 2019 10:51 AM
Philip Garcia
Nov 10, 2017 10:01 AM
Robert Grisar
May 28, 2017 01:53 PM
Bob OB
Nov 16, 2014 05:13 PM
RJ237
Aug 14, 2012 12:56 PM
