Changing Oil cooler hoses...a word to the wise
Old Jun 19, 2020 | 06:01 PM
dbtk44's Avatar
Lightbulb Changing Oil cooler hoses...a word to the wise
So, a while back one of my oil cooler hoses burst on the AZ highway @80mph, and left just about all my oil in the road behind me. I probably had her off the road within 10 seconds of hearing the warning chime and seeing "No oil pressure" warning on the dash. No real harm done I think, but I was very lucky.
Anyway...should this travesty visit you ( which I sincerely hope it does NOT ), a word to the wise: BEFORE you order the oil cooler lines, visually inspect the lines themselves, ESPECIALLY the front side connections, and take note of their appearance before you go order the new hoses.
A previous owner had apparently opted to install an AFTERMARKET oil cooler in place of the OEM Jag cooler, who's connectors at the cooler itself were not even remotely like the JAG connectors. Luckily I found a good shop that could replace the bad fitting(s) on the right side front hose, for less than $50.00. But, this is after having ordered 4 hoses at @$120-130 each, and ending up having 2 hoses that I can't use.
I know...it seems like common sense, right?
Just wanted to share this, so the next guy or gal doesn't make the same mistake I made. Carry on Lads! And lassies!
Old Jun 20, 2020 | 03:33 PM
brinny's Avatar
Good on ya.
CalebT31
Jun 19, 2020 03:19 PM
Roger95
Dec 16, 2015 09:09 AM
RagJag
Jun 19, 2015 07:51 AM
orangeblossom
Feb 11, 2013 02:40 PM
cocco78
XJ40 ( XJ81 )
Jan 17, 2011 06:27 AM
