Chassis Leg Rust
Old Oct 9, 2016 | 02:13 AM
blackjaguarxk8's Avatar
Default Chassis Leg Rust
Hi,
After doing some investigating behind one of my rear wheels I've discovered some rust on the chassis leg, do you know if this is an MOT fail ?
best pic i could get without taking the wheel off again
Old Oct 9, 2016 | 03:08 AM
Mark Murphy's Avatar
Yes, unfortunately it does need a plate welded in, i just done my fronts on my x308.
Old Oct 9, 2016 | 04:55 AM
how much did it cost you?
Old Oct 9, 2016 | 05:06 AM
phanc60844's Avatar
They may fail the fuel lines as well from the picture. Get some rust converter on them followed by some waxoyl, Dinitrol is my fav though
Old Oct 9, 2016 | 05:20 AM
RaceDiagnostics's Avatar
Mine were rusty for a while and were not noticed by my MOT station, however any rust within 30cm of a suspension point should be a fail.
It can be an expensive job as the rear suspension/subframe diff etc needs to be removed to get good access.
See what is involved here. https://www.jaguarforums.com/forum/x...repair-149852/
Old Oct 9, 2016 | 05:22 AM
Nothing, as i did all my own welding
Old Oct 9, 2016 | 08:01 AM
Maybe it's worth rebuilding the suspension of its all gotta come out
Old Oct 9, 2016 | 09:00 AM
If you plan to keep the car, now's the time to do it.
Old Oct 9, 2016 | 09:20 AM
I want to keep the car as I've wanted one since i first saw them... most people think I'm crazy spending money on it !
Old Oct 9, 2016 | 11:31 AM
andyzeg's Avatar
Yes...I'm afraid it is an MOT fail as my XK8 failed for the exact same thing in the Spring. Fortunately I was able to weld it myself...but it was very tricky due to the position and angles involved. Also, as it looks like the passenger (left) side..the pipes you can see clipped in place on the chassis member in the photos you took are petrol pipes...so extreme caution is needed here.
Hope it goes well for you.
Unless you have checked this already...if you are having welding done....it is well worth checking out BOTH front footwells for the dreaded XK8 double skin rust problem and also the rear floor corners of the footwell at each end of the rear seat which can rust through.
Old Oct 9, 2016 | 02:58 PM
Well i guess i gotta add this to the list of many things to fix.
I've just got my car back yesterday from the body shop fixing the rear lower sill and painting one side of the car. Its booked in to do the floor panel next month.
383 Jag
Nov 28, 2024 10:06 AM
Atlastajag1
Sep 26, 2016 03:28 PM
michaelodonnell123
Sep 18, 2016 12:25 AM
shemp
Sep 14, 2016 01:25 PM
4litre
Sep 14, 2016 12:52 PM
