Climate control module lighting
Old Apr 14, 2020 | 10:00 AM
Barry_Tucker's Avatar
Default Climate control module lighting
The left half of the display on my climate control module has gone dark. Does anyone know if it is possible to replace bulb(s) in this or will I have to either love with it or order a replacement part ?
Old Apr 14, 2020 | 11:47 AM
avern1's Avatar
They are replaceable. Below is a link to Reverend SAM a members DIY you tube video. I am in the middle of doing mine.
Old Apr 14, 2020 | 12:36 PM
Jon89's Avatar
Very common issue. Just follow Sam's video above....
For best results, replace BOTH bulbs at the same time so you will not have to go in there again....
Old Apr 14, 2020 | 01:52 PM
rothwell's Avatar
I covered replacing those bulbs in my working thread. Details are there about types of bulbs to buy too.
Old Apr 14, 2020 | 02:18 PM
LOVE this forum. Thanks folks. I will have a go at replacing the bulbs
Old Apr 14, 2020 | 09:38 PM
rothwell's Avatar
If you have not had the center console apart before, its worth mentioning that the plastic frame that holds all those components is likely to be fragile so be careful. Mine cracks somewhere every time I take it apart.
Old Apr 14, 2020 | 10:20 PM
crbass's Avatar
Indeed, one of my frames is a comprised mostly of epoxy and hope. This would be the perfect thing to scan and print if I had a 3D scanner this large. The 'design flaws' could also be fixed at that time.
Old Jan 1, 2021 | 05:22 PM
Bob Boyle's Avatar
Default X100 Climate control panel lighting
I have a couple of switches were the letters no longer light up, Defrost and Rear. I this the correct part number for the bulbs, if so would I need one for each switch?
JLM20308
srjag
Oct 22, 2023 08:29 AM
1927
May 20, 2018 11:18 AM
caveforce
Jan 14, 2015 01:25 PM
Dirk Bailey
22
Jan 27, 2013 07:22 AM
Glendoramike
Sep 24, 2011 05:23 PM
