coil D
Old Jun 9, 2017 | 12:09 PM
graham11's Avatar
Default coil D
Hi guys,can anyone point me to coil D as I have a restricted performance issue and my diagnostic tool tells me it's a coil D problem,thanks
Old Jun 9, 2017 | 12:42 PM
avern1's Avatar
Mot diagnostic tools use generic definitions and often don't match up with Jaguar. The tool should have given you a P code such as P0301, P0302 etc. If you post the actual code then we can tell you what coil might be causing a problem. I really don't know what a D coil is, at least not on a Jaguar.
Old Jun 9, 2017 | 01:32 PM
graham11's Avatar
Default coil D
The code i am getting is po354,thanks,p's also says bank1 censor2
Old Jun 9, 2017 | 05:35 PM
avern1's Avatar
P0354 indicates a misfire on cylinder 4. The possibilities are a bad coil, bad wiring or a bad Engine Control Module. For troubleshooting remove the #4 coil and swap it with a different coil. Then clear the codes and run the engine and see if the fault moves to the new location of the coil. If it does then simply replace the coil.
You don't list the MY of the vehicle so assuming it is an XK8 I have attached the 2 different numbering sequences that were used for the XK8.
Old Jun 10, 2017 | 08:28 AM
graham11's Avatar
Default coil D
Thank you,I will give it a go and keep you updated
Old Jun 10, 2017 | 11:58 AM
Brutal's Avatar
D is between c and e. Or #4
Old Jun 11, 2017 | 08:04 AM
graham11's Avatar
Default coil D
conflicting Information i am getting on various on line site's is that this is coil D but need 100% reassurance ,sorry for being a pain in the butt
Old Jun 11, 2017 | 10:01 AM
avern1's Avatar
I think what you have checked is correct for coil D, cylinder 4. I am sure that since the code reads P0354 that you are looking at the correct one. I think the reason for the updated cylinder numbering is to mirror what OBD testing identifies.
Old Jun 11, 2017 | 10:15 AM
graham11's Avatar
Okay and thanks for all your help it's much appreciated 👍, day off work Tuesday so will give it a go
Old Jun 12, 2017 | 01:51 PM
graham11's Avatar
Well today I changed the spark plugs and fitted new coil,old plugs looked shot at,car performance was great for around 15miles then restricted performance came up again now I am stumped,any idea what to try next anyone
Old Jun 12, 2017 | 04:47 PM
Brutal's Avatar
Originally Posted by graham11
conflicting information i am getting on various on line site's is that this is coil d but need 100% reassurance ,sorry for being a pain in the butt
this is correct. Aka 1,3,5,7 on the left and 2,4,6,8 on the right
Old Jun 13, 2017 | 05:19 AM
graham11's Avatar
Thank you,got the car booked in at my local indi jag center in the week for full diagnosis there comes a time enough is enough 😠
Old May 13, 2022 | 09:32 AM
JEZZA's Avatar
It's an old tread but what did you come up with?
Old Jun 26, 2024 | 05:33 PM
tlindi's Avatar
Default Usually people just dont care others...
As usual, here is one other owner looking for help (if discard or fix the car) but people just don't care. As soon as their issue is solved, they forgot everyone who spend time to help them. /rantend
Old Jul 1, 2024 | 08:28 AM
JimmyL's Avatar
Talking Closing
I agree with this. Happens all the time.
The cylinder numbering post cracks me up. Only on a Jaguar diagram would the cylinder be labeled "2" on the inside "6" on the outside, but no that's number "4" for sure. ;^) (It might be "coil D" too !)
Old Jul 1, 2024 | 06:14 PM
Shoreguy's Avatar
Veteran: Air Force
Yeah, I agree not reporting back or giving an update is just bad manners.
Jimmy, I'm going to give Jaguar a break on the cylinder confusion. It is really frustrating trying to figure out cylinder numbering or firing orders among many different manufacturers. On many common vehicles two different sources of tech info will give you two different answers or illustrations. I don't understand why these things are hard? lol
JigJag
Jun 3, 2023 12:42 PM
leaddog11
Feb 14, 2023 10:52 AM
alanroberts50
Jul 7, 2020 07:13 AM
JameyXJ6
Apr 10, 2012 12:34 AM
