Compression Problems Update & Question.
Old Jan 27, 2022 | 08:38 AM
Phil m's Avatar
Default Compression Problems Update & Question.
Hi All,
Last year I created the following post regarding my 1999 4.0L XKR RH convertible (non starter) having issues with the compression being all over the place with 8 boar having zero compression.
https://www.jaguarforums.com/forum/x...ailure-249714/
Due to Covid, Lock Downs and having to find another place to store the car I'm looked at this again. It turns out a primary chain has snapped which means the piston has come in contact with a valve or two.
My new mechanic (who I trust more than the old one) has only just looked at it but is going to removed the head and check the sump to confirm things over the next few days but he thinks all 4 chains will need to be replaced as he's going to have to take the front of the engine off anyway.
I'm UK based and was wondering if a kit exist that contains all 4 chains etc?
Old Jan 27, 2022 | 09:58 AM
zray's Avatar
I can’t directly answer the question.
But will observe that aftermarket parts quality is often poor. Timing chains would be one area of which I’d want the highest quality parts available.
Which usually is going to be the Jaguar manufactured parts. No amount of saving would prompt me to use an eBay sourced kit for any internal engine parts.
Additionally, many eBay parts that are advertised as being OEM Jaguar manufacture are counterfeit, with fake logos, etc.
Z
Old Jan 27, 2022 | 10:10 AM
Phil m's Avatar
Totally agree Zray, no point in spending to momey to replace the chains for poor quality ones as I'd only have to replace again sooner rather than later.
Old Jan 27, 2022 | 01:50 PM
drmike's Avatar
Like this kit? It probably isn't what you want but Berkshire seem to be good at kits.
Old Jan 27, 2022 | 02:05 PM
Phil m's Avatar
It looks like what I need but need to check with them who the manufacturer is.
Thanks Mike
Old Jan 27, 2022 | 02:12 PM
drmike's Avatar
Yes you do but I have found them to be pretty clear on most things although I haven't yet bought anything from them as my local SNG Barrett is within a couple of quid for most things and I can drive there (Bridgnorth).
bazanaius
May 11, 2015 05:06 PM
Chughes2014
Aug 30, 2014 05:58 PM
AristoCat
Feb 7, 2014 09:44 PM
viscoussquirrel
Feb 11, 2010 02:59 PM
Rock Meathammer
Apr 15, 2008 02:59 PM
