Convert top
Old May 29, 2025 | 07:52 PM
MRomanik's Avatar
Veteran: Air Force
Default Convert top
Hi all.Last winter the top would not close, so I did a manual close and jumpered the relays to close the rear windows. This year, the top would not open. I did some reading and found a mustang post that suggested removing and reinserting the convertible top relay. I did this and the top opened as designed.
I thought it would be a good idea to install "Rev Sam" (sam1174) switch to control the rear windows from his video in 2011. I disassembled the armrest looking for a green/black on pin 11 and green/purple on pin 15. I found a green/black on pin 17 but I can't find the green/purple. Any suggestions?
Thanks in advance
Old May 30, 2025 | 12:29 PM
barnter's Avatar
I thought this was a feature on the cars already.
@mikemasten3252
Nicely done, except that the roof button does the same and I'll explain.
1. Long press the roof button up or down with the engine running it raises and lowers the roof and rear windows.
2. Tap the roof button in either direction and it ONLY raises or lowers the rear windows and the roof doesn't move.
Old May 30, 2025 | 12:46 PM
waltwagner's Avatar
Actually, in the video Rev. Sam specified the green/BLUE wire, not green/purple. You can see the green/blue one to the right of your red circle.
Old May 30, 2025 | 06:16 PM
MRomanik's Avatar
Veteran: Air Force
Sam added an addendum in the comments. So I'm confused>
@sam1174
@piehandseddie I just looked at the manual. It looks like the wires are in the same location, however they are different colors on the 1997. The wires you are looking for are green/black and green/purple. They are on pins 11 and 15 (on the 2003 they are on pins 16 and 17). So, it's the same connector, but you're looking for the green/black wire on pin 11 and the green/purple wire on pin 15.
Old May 31, 2025 | 09:20 AM
MRomanik's Avatar
Veteran: Air Force
Barnter
Tried this it didn't work
Old May 31, 2025 | 05:11 PM
barnter's Avatar
Is this helpful?
http://www.jagrepair.com/images/NonS...ifications.pdf
Old May 31, 2025 | 05:44 PM
LMG's Avatar
LMG
Originally Posted by barnter
I did the mod per Sam's original video and then followed up with Part II of these instructions from JagWrangler (whiteXKR). Been completely happy with it. Note that Part I is no longer recommended as it was found out that the roof-up button wasn't up to the task in the long run, see post #202 in this thread https://www.jaguarforums.com/forum/x...-37826/page11/
Old Jun 1, 2025 | 09:27 AM
MRomanik's Avatar
Veteran: Air Force
Thanks.
I read this and it seems more complicated work than I can do.
Old Jun 1, 2025 | 10:39 AM
MVMonarch's Avatar
“A man’s got to know his limits”.
I find this Hollywood quote is very useful to avoid projects beyond my knowledge or skill set.
Old Jun 1, 2025 | 10:52 AM
LMG's Avatar
LMG
But how do you find the limit and how do you expand your skill sets?
Since OP is savvy enough to locate and tap into the connectors under the center console, he very likely has the skills needed to wire up the relay and the pulse timer for the autodown feature. I speak from my experience; I only had a little electrical skill when I tackled this, but the instructions are easy to follow and everything is relatively accessible compared to what we usually have to deal with when doing mods or repairs.
I'd say go for it!
Old Jun 1, 2025 | 01:40 PM
robak's Avatar
@mikemasten3252
4 years ago
hey. that is not fully correct.
tapping the roof button only lowers and ups the rear windows when the roof is closed, as it is one of the last/first steps in the roof closing/opening sequence.
if the top is down. you cant tap the button to only up the rear window. Top down: only front windows up
Old Jun 1, 2025 | 03:17 PM
MRomanik's Avatar
Veteran: Air Force
. At 78 yrs old with neuropathy in both hands, I know what I can and can't do anymore,
Old Jun 1, 2025 | 03:22 PM
MRomanik's Avatar
Veteran: Air Force
So I tried tapping the green/black and green/blue wires. No luck. Maybe the taps are junk. Too hot outside so tomorrow I will try to ascertain if there is power at the taps.
Old Jun 2, 2025 | 12:52 PM
MRomanik's Avatar
Veteran: Air Force
I have power to the green/black wire but no power to the green/blue wire. Maybe my wiring is an anomaly for an early '97.
erjent
Feb 11, 2023 09:07 AM
Luke Farrell
May 2, 2019 08:07 PM
Salo
Jun 18, 2018 10:31 AM
Big Cat
Jun 21, 2013 06:59 AM
jagosaurus
Apr 6, 2013 07:01 AM
