Convertible Top issues
Old Jul 21, 2021 | 06:02 PM
Taylor Kowitz's Avatar
Default Convertible Top issues
Went to go put the top down on a nice evening and it was able to unlatch but it hesitated then stopped. Went to check the reservoir and it was empty! Saw a lot of people talking about the top latch drip but I haven’t seen any of that. I did find a stream coming out behind the rear passenger wheel arch. Any help is appreciated
Old Jul 21, 2021 | 09:28 PM
Gus's Avatar
Gus
Sounds like a ram/lift hose or the ram seal.
Gus
JagRepair.com - Jaguar Repair Information Resource
Old Jul 21, 2021 | 11:31 PM
DavidYau's Avatar
Default Probably a broken connection at the pump
Taylor,
Take off the trunk carpet trim on the right hand side, which will reveal the hydraulic pump.
As you’ve got drips from the right rear wheel, I would guess that a pipe connection has broken at the pump. The black pipes has a known weakness at the crimped joint to the end connector.
How do I know... I had exactly the same problem. Cleaning up all the split oil in the trunk is a pain, especially as there’s a lot of electrical connections in the area plus body grounds.
Old Jul 22, 2021 | 10:52 AM
as Gus and David have stated - sounds like the ram hoses have failed. Best to get the higher rated hoses from either Cabriolet Hydraulics or Top Hydraulics. Both have a comparable pressure rated product and offer great support, I used Cabriolet Hydraulics just due to proximity to me and able to get hoses faster at the time. Price was the same.
It is a DIY job so check the link Gus provided as it will get you through!!
Old Sep 15, 2021 | 08:31 PM
Originally Posted by DavidYau
Taylor,
i have confirmed that the retracting top line going into the pump has blown off on the fitting. I stuck it back in and actually was unable to get it out by hand so I tested the motor. I filled the reservoir and ran the top down and back up. As soon as it latched the same hose blew off. Is there a way to get a new fitting for that? The fitting goes into a T and then into the motor. If a guy could put a fitting in and crimp the line it’s be done and done.
Old Sep 15, 2021 | 09:47 PM
Gus's Avatar
Gus
Your best option would be to replace the hose.
Gus
Jack Rabbit
Nov 19, 2022 08:42 PM
Dennis07
Aug 13, 2020 08:40 PM
reefhunter100
Nov 25, 2018 09:59 PM
reb1999
Jun 21, 2016 06:23 AM
moonpetal38
Feb 4, 2012 04:43 PM
