Convertible Top Latch
Old Sep 15, 2016 | 07:33 AM
walkman1's Avatar
Default Convertible Top Latch
The center latch for my convertible top seems to be hesitating a little before it locks in when I close the top. The fluid level in the pump is within the normal range, and I installed a current reducer several years ago. The hydraulic line was spliced a few years ago. Any ideas? I guess there could be a small leak that would reduce pressure and be in an area that is not visible.
Old Sep 15, 2016 | 07:45 AM
test point's Avatar
The latch gets a little stiff over time and the hydraulic pressure may be taking a moment to overcome that. A little spray lubricant will usually free it up.
Old Sep 15, 2016 | 01:28 PM
brgjag's Avatar
what is "A LITTLE TIME"? My 03 it seemed to wait a second or so before it latched her down. I would thing it could very for many of us based on age, this that and the other.
Old Sep 19, 2016 | 05:01 PM
walkman1's Avatar
I lubricated the latch after I lowered the top and we will see what happens when I raise it again. I did find out one new quirk. The top will not lower with the trunk open. I hit the button and the quarter windows went down, but nothing else happened.
Old Sep 19, 2016 | 06:42 PM
Jandreu's Avatar
Thats not normal, my 03 will go either way without issues with the trunk open.
Old Sep 20, 2016 | 02:15 PM
pbuck's Avatar
So will mine, an 01.
Old Sep 21, 2016 | 07:00 AM
walkman1's Avatar
It's probably not an open trunk issue. It was reacting very slow to the button (not reacting at all), and I have had two line failures, so I am hesitant to keep pushing the button with no latch response. Owning one of these keeps you on edge waiting for the next issue to pop up.
Old Sep 21, 2016 | 08:00 AM
Dennis07's Avatar
I have tried to tweak the hydraulic system on my car so as to produce a pressure pulse just barely adequate to close the latch. Any more than that makes life harder on the hoses. But cutting things close like this, every now and then the top needs a little help ... i.e. manually pulling down on the top as the latch is trying to close.
Pulling down the top like this may be worth a try in your case. Even if you would not want to operate the top this way long term, it would be an informative test.
lowkeycm
Jun 8, 2023 04:47 PM
Helen Serrano
Oct 2, 2016 04:14 PM
oddjob2000
Sep 15, 2016 04:15 PM
dustybarn
Sep 15, 2016 09:13 AM
