Coolant glycol- still flammable?
Old Dec 8, 2022 | 11:29 AM
Johnken's Avatar
Default Coolant glycol- still flammable?
Now this one's probably obvious but I just read something that surprised me. An article on air cooled vs. liquid cooled allied fighters in WW2 (P47, Hellcat(?) With Pratt and Whitney air cooled vs Spitfire, P51 Merlin engines for example) discussed the trials and headaches associated with using super high tolerance engines, aka Rolls Royce Merlin liquid cooled, on carriers with the salt water environment. They had to rebuild these engines every 240 hours! Besides tolerances, liquid cooled issues were a factor - magnified with each "controlled crash" landing on carriers.
Yes I knew about the superior survivability and ruggedness of air cooled (errant bullets can't cause loss of temperature regulation), but I was surprised they mentioned another critical fact: Glycol is (was?) quite flammable!
Now I've always been ultra careful with coolant regarding the fact its both real tasty and - really f'ing poisonous to dogs and I assume cats, but I've never thought about flammability. Are our coolants still flammable?
Yes I should know this one already, but . . .?
Thanks,
John
Old Dec 8, 2022 | 12:04 PM
Jon89's Avatar
Never heard of a coolant fire. I'm sure it contains various chemicals that would burn on their own, but proper coolant is at least 50% water. My guess is that it would take a monumental effort to make it burn....
Old Dec 8, 2022 | 03:35 PM
RJ237's Avatar
It will burn. A mist exposed to high temp will support combustion. MSDS:
Microsoft Word - SDS MAJ-602, 604, 606 - 50-50 Antifreeze - SDS-MAJ-602-604-606-50-50-Antifreeze.pdf
Old Dec 8, 2022 | 06:27 PM
Johnken's Avatar
Thanks guys!!
Old Dec 9, 2022 | 10:36 AM
kansanbrit's Avatar
What a strange thread.
Old Dec 9, 2022 | 03:17 PM
Johnken's Avatar
And, what a positive comment! You probably don't realize the coolant in your car contains glycol. . . Be safe k.
Old Dec 10, 2022 | 10:10 AM
kansanbrit's Avatar
What the hell does it have to do with Jaguar x100 specifically ? Cracra.
Old Dec 10, 2022 | 01:02 PM
Johnken's Avatar
I know, its complicated k: Don't drink that green stuff that leaks out of your x100's engine or - as I too have just learned - don't let it get near a flame.
Got a dog? Reread OP.
But thanks for asking :-).
John
Old Dec 13, 2022 | 05:39 PM
Throwback's Avatar
I would imagine aircraft engines used a more concentrated glycol, plus from the perspective of carrier ops, the greater danger is on the hanger deck where they would presumably have the stuff in concentrated for in a restricted environment.
However, +1 on not really Jaguar related? lol.
On a random aside, there's a group in Sweden (I think) building a ford crown vic with a RR meteor in it that theyve added turbos to, and they have it running EFI on a megasquirt ECU which I find mildly amazing.
Old Dec 13, 2022 | 06:32 PM
RJ237's Avatar
According to the MSDS, which it appears almost no one read, 50/50 is flammable, particularly as a spray from a pinhole leak.
Old Dec 17, 2022 | 04:43 PM
Don B's Avatar
Well, presumably your X100 uses engine coolant based on ethylene glycol, so this seems like a subject worth knowing about, and I'm grateful that Johnken brought it up and RJ had the wisdom to find the Material Safety Data Sheet.
If I read the MSDS correctly, 50/50 ethylene glycol/demineralized water is combustible but not flammable. This means the temperature at which it will combust is relatively high. Flammable substances will ignite at relatively low temperatures. Here's a snip from Section 5 - Fire Fighting Measures:
If you then refer to Section 9 - Physical and Chemical Properties, you'll see the Flash Point, which is the temperature at which the substance will combust. If our Jaguar is running with underhood temperatures above 130°C / 266°F, we probably have more to worry about than whether the coolant is going to combust!
Cheers,
Don
Brian H Smith
Nov 12, 2022 03:01 PM
footbrake
Aug 28, 2016 11:49 PM
Rey
Aug 14, 2015 02:14 PM
stephen11962
Apr 7, 2013 08:26 AM
cory620
Jul 20, 2010 03:59 PM
