Coolant once more - what do i get?
Old Jun 25, 2022 | 04:04 PM
chillyp's Avatar
Default Coolant once more - what do i get?
Hello,
Recently I've intermittent low coolant level show up on the dash as I do not know when to coolant was changed in the car I decided to flush the coolant and replace it. This is where everything went sideways, I can't seem to find the right coolant. I searched the forums and found members comment that the right specification for the coolant is WSS M97 B44D but I can't see to find a coolant with that spec for my 98 xk8.
Went by to auto zone and the sales agents definitely do not know head or tail of coolant system and was making recommendations that didn't make sense (get any applicable coolant and top it off he said).
The ford engine on a european car makes the choices confusing. I buy most of my stuff from rock auto and rather than asking which coolant I should get I thought it might be easier to provide a few options and someone could help me select one. These options are from the ones RockAuto presented to me as alternatives for 98 xk8
European models - teal color covers jaguar years 98.
https://www.rockauto.com/en/moreinfo...11393&jsn=1330
Recommended for Ford
https://www.rockauto.com/en/moreinfo...11393&jsn=1328
For use in GM and Ford
https://www.rockauto.com/en/moreinfo...11393&jsn=1325
For use in all vehicles
https://www.rockauto.com/en/moreinfo...11393&jsn=1324
My last option is to go to the jaguar dealer and pick up what they sell me.
Appreciate help on selecting one. Thanks everyone
-Bhaskar
Old Jun 25, 2022 | 04:24 PM
chillyp's Avatar
Just after I posted I found rock auto also lists this with the exact spec
https://www.rockauto.com/en/moreinfo...=1331&jsn=1331
This is in concentrate form, guessing I should go with this one?
Old Jun 25, 2022 | 05:03 PM
michaelh's Avatar
Hi chillyp,
Here's the Jaguar coolant spec:
Up to late '98 cars used the DOW (green, IIRC) coolant, after which there was a changeover to the Ford spec WSS M97 B44D (orange, usually).
You are wise to do a full flush if you're not 100% certain what's already in there (hence the warning about mixing types), after which you can use either DOW or WSS.
The part linked in your second post matches WSS. I changed over to that Ford spec at least 10 years back and have had no problems.
Old Jun 25, 2022 | 06:10 PM
chillyp's Avatar
Thank you. Going with the BECK/ARNLEY 2521021 concentrate. Appreciate your response. @michaelh
Old Jun 26, 2022 | 11:01 AM
motorcarman's Avatar
Jaguar used D542 (yellow) until the change to XL coolant (orange) 042635-ON (X100) and 878274-ON (X308).
File Type: pdf
newjagowner
Oct 5, 2012 04:44 PM
JagManBonano
Sep 5, 2012 05:59 PM
cagsjag
22
Sep 28, 2011 10:43 AM
plums
Jul 8, 2011 01:33 AM
2000blackxkr
Dec 26, 2008 09:25 PM
