Correct battery for the xk8
Old Apr 8, 2018 | 10:06 PM
Jagxk891's Avatar
Default Correct battery for the xk8
Hi all, looking to replace the battery in the xk8 I know that the OE battery for a XK8 is a VARTA made in Germany. Part Number C2D22312. Specification is 90Ah and 800 amp, dimensions 354 x 175 x 190mm is 019 and the short code is H3. So I have looked on Vartas web site and put the part number and it brings up a varta Blue Dynamic 595 402 080 near enough that same spec only the short code is G3. Any thoughts on this and if its a good idea to get the battery? I will leave the link bellow.
https://www.varta-automotive.com/en-...ic/595-402-080
Old Apr 9, 2018 | 03:08 AM
toaster's Avatar
Why not the Silver Dynamic?
https://www.varta-automotive.com/en-...84+PS%29%22%7D
Old Apr 9, 2018 | 12:33 PM
Jagxk891's Avatar
The silver dynamic is 100ah and 830A, bit worried it would over do it as the electricial system is very sensitive in these xk8s
Old Apr 9, 2018 | 03:35 PM
JagV8's Avatar
It won't mind it.
Old Apr 10, 2018 | 06:23 AM
toaster's Avatar
The Silver Dynamic is recommended by Varta for the XK8!!!!!!!
Old Apr 10, 2018 | 08:54 AM
CorStevens's Avatar
the battery capacity is different than say a charging adapter output. the numbers for a battery represent its capacity under load for a period of time. note that voltage drops due to insufficient capacity can damage electrical components as things run hotter. install the highest reserve battery that you can. Bosch has a 1080A lead acid for a very good price.
Old Apr 10, 2018 | 04:23 PM
rothwell's Avatar
I installed one of these AGM types back in September 2013 and it is still going strong.
They don't sell that exact one anymore but here is a
link to the newer model Only $155 when ordered online using their 20% off coupon.
Terry007
Feb 5, 2018 04:21 AM
hoya_loya
May 27, 2015 08:50 PM
dannyS
Apr 12, 2013 09:42 PM
