crank pulley ring seal
Hello, all - I'm part way through reassembly of my 2000 XK8 4.0L n/a engine, have reinstalled the timing cover. Is it absolutely necessary to replace the small sealing ring inside the bore of the crankshaft damper pulley? (Not the main seal, which I've done - the small ring that is seated inside a groove in the damper body). The old one appears to be undamaged.
Thanks for any suggestions.
Crispy describes it elegantly. I had a replacement sealing ring in the gasket kit I received, didn't realize it until I took the old one out and had a good look at it. It would be helpful if these gasket and sealer sets had labels, but without guesswork, where's the fun?
pdowning6
Jan 10, 2024 07:16 AM
WaterDragon
Feb 12, 2014 07:15 AM
