crank pulley ring seal
Old Nov 3, 2023 | 08:50 AM
aced704's Avatar
Default crank pulley ring seal
Hello, all - I'm part way through reassembly of my 2000 XK8 4.0L n/a engine, have reinstalled the timing cover. Is it absolutely necessary to replace the small sealing ring inside the bore of the crankshaft damper pulley? (Not the main seal, which I've done - the small ring that is seated inside a groove in the damper body). The old one appears to be undamaged.
Thanks for any suggestions.
Old Nov 3, 2023 | 08:59 AM
motorcarman's Avatar
The thin 'O'ring is usually very 'crispy' and breaks into small pieces when removed from the groove.
If you can remove and reinstall, then it might be pliable enough for reuse?
Old Nov 3, 2023 | 12:56 PM
aced704's Avatar
Crispy describes it elegantly. I had a replacement sealing ring in the gasket kit I received, didn't realize it until I took the old one out and had a good look at it. It would be helpful if these gasket and sealer sets had labels, but without guesswork, where's the fun?
pdowning6
Jan 10, 2024 07:16 AM
iTh3 Riddler
Nov 8, 2022 05:58 PM
OUScooby
Apr 19, 2019 11:02 PM
WaterDragon
Feb 12, 2014 07:15 AM
Simprof
Mar 26, 2011 06:28 PM
