Dead Steering Wheel - Cancellation Cassette Module
Old Jan 29, 2018 | 08:41 PM
JayJagJay's Avatar
Default Dead Steering Wheel - Cancellation Cassette Module
Hello Folks
Seeking some help and guidance here.
Some time ago everything on my steering wheel went dead. I checked fuses and thru research I cannot figure out if there is a fuse that powers ALL cruise, stereo controls, horn, phone button (which I do not use)... Basically powering the wheel controls... Actually, finding fuses for individual components (less horn) proves impossible.
Today, I tore apart the steering column thinking that I might find a frayed, damaged or pulled apart plug,,, nothing. BUT,,, I found a 'thing' that I had never seen before or knew existed. The CANCELLATION CASSETTE MODULE (see link)...
Does anyone have experience with these things? I can find them on line (and will purchase if) but was hoping I might get pointed in a few troubleshooting directions before spending the $$60-70-80 bucks and/or hear peoples opinions.
GIANT thanks in advance for any suggestions and answers...
Old Jan 29, 2018 | 10:06 PM
Lady Penelope's Avatar
If you take a file and file the corner off all the way around you will find either a ribbon cable coiled up loosely so that when you turn the coil tightens up or loosens up further . The soldier points at either end of the coil breaks and can be stripped down a little and resoldered .
The other style has wiper brushes on several rings that can be cleaned up with a pencil eraser .
After the repair you can epoxy the corner you filed off back up .
Old Jan 29, 2018 | 10:10 PM
JayJagJay's Avatar
HI... Thank you.
So I had the part out today. It is the ribbon sort. When you say file, do you mean the back or the front of the part? The plastic cylindrical portion? Where exactly? Is it known to fail and is it PROBABLE that this is my problem considering ALL and everything on the wheel failed?
Very grateful. Sorry to bomb ya with questions
Old Jan 29, 2018 | 10:15 PM
Linked video above may get you further as I have not tinkered with one on a Jaguar
Old Jan 29, 2018 | 10:21 PM
JayJagJay's Avatar
NICE!!!
Thanks for the vid Lady P... Ill post a questions here that I added as an "edit" to my first reply back to ya... I appreciate your help
*****In your experience,,,, is it known to fail and is it PROBABLE that this is my problem considering ALL and everything on the wheel failed?*****
Looks easy enough to TRY and fix. Ill try before spending $$$$$
Old Jan 29, 2018 | 11:04 PM
I don't have the experience to give a % chance but if the one of the several wires in the ribbon is a bad ( the other ones being feedback ) power wire then it's 100 %
Old Jan 29, 2018 | 11:39 PM
JayJagJay's Avatar
Understood...
car5car
May 5, 2017 09:31 AM
carzaddict
Aug 24, 2016 03:35 PM
vdpnyc
Feb 24, 2016 01:57 PM
firstxf
Mar 14, 2013 05:45 PM
supraman
Jul 17, 2011 11:14 PM
