Detect vacuum leak with t/b cleaner?
Old Jul 27, 2020 | 09:48 PM
Jeff390's Avatar
Default Detect vacuum leak with t/b cleaner?
Just a quick question. Can you use either throttle body cleaner or MAF sensor cleaner to detect a vacuum leak by spraying around suspected area? I've heard of using carb cleaner but don't have any of that. If there is a leak will the idle increase? Cheers Jeff
Old Jul 28, 2020 | 04:43 AM
bladerunner919's Avatar
Yes, should do the same. You might also try using a length of hose as a stethoscope, with one end in your ear and the other end probing around the suspect area listening for the tell-tale hissing.
Old Jul 28, 2020 | 04:49 AM
As another option, this thread on a BMW forum that I also frequent might be a more satisfactory solution: https://www.bimmerforums.com/forum/s...e-smoke-tester
Old Jul 28, 2020 | 09:04 AM
darbysan's Avatar
I like to use starter fluid ( the car kind- not the barbecue type ). It evaporates well, and doesn't leave any residue.
Old Jul 29, 2020 | 09:50 AM
Aarcuda's Avatar
I had NO LUCK using carb cleaner. The engine sound in my 06 str did not change as the pcm immediately corrected for it. I could see the change on the o2 sensors voltages and currents using SDD using the monitoring function
Old Jul 29, 2020 | 11:21 AM
motorcarman's Avatar
You would be better off watching the STFT while spraying the fluid.
Old Jul 29, 2020 | 12:51 PM
Aarcuda's Avatar
I had those up on the screen too. I cant remember which one wiggled the most. But ya
Old Jul 29, 2020 | 11:15 PM
zray's Avatar
You can use plain water in a spray bottle. The motor’s idle will change if there is a vacuum leak, similar to the idle change observed when using the highly flammable sprays already mentioned.
water has several pros, and no cons.
pros+ :
wont catch on fire
is really cheap
easy to find H2O
little to no residue (use distilled water If you want to avoid mineral spotting)
​​​​​​cons :
none
Z
Old Jul 30, 2020 | 06:53 AM
JagV8's Avatar
Cons: water is not going to go through some tiny leaks so won't help if that's the problem.
Old Jul 30, 2020 | 07:51 AM
zray's Avatar
Ive never had the water test fail yet in 50+ years . But I suppose there’s always a first time.
Z
Old Jul 30, 2020 | 08:22 AM
scottatl's Avatar
they are tricky on this car I have one I cant find. I have smoked it, soaked it, and throttled it. the damn thing is elusive.
Old Jul 30, 2020 | 10:46 PM
Jeff390's Avatar
Thanks Guys. I have what sounds like a massive leak somewhere around the supercharger. See my other post below. Noticed a small but repeatable idle increase at front of s/c inlet pipe. Ordered another gasket. Spent hours fitting it (with other maintenance). Didn't make one bit of difference! I've never owned such a frustrating car. I love the thing but seriously starting to think that I spend more time rolling round underneath it than driving it!...
Old Jul 31, 2020 | 01:17 AM
scottatl's Avatar
i hear ya......
Old Aug 5, 2020 | 02:37 PM
beaterbeliever's Avatar
I feel you on that, definitely spent more time under the hood than driving it.
fvierra27
Sep 29, 2025 10:51 PM
Jaizero
May 18, 2024 04:33 PM
steve_k_xk
May 31, 2017 12:47 AM
dx3
Mar 22, 2012 10:12 AM
e21pilot
Apr 9, 2010 06:48 AM
