You need to add hydraulic fluid all the way to the embossed fill line on the tank (which is about halfway up). Looks like yours is significantly low....
The correct fluid is Pentosin CHF11S (colored green). NAPA sells it as do a number of other auto parts stores....
If the fluid is NOT in the overhead console, then it will be in the floorboard under the lift rams behind the rear loudspeakers or under the pump itself.
I used some siphoning hose since I did have an appropriate funnel handy. I sucked the long-ish siphon hose mostly full, plugged it with my thumb, stuck the hose into the tank and released it.
Anthony, grab a big old turkey battery to add the new Pentosin fluid. It's an awkward angle.
John
A couple feet of hardware store plastic hose added to the turkey baster works better than the baster alone. Fairly small hole so keep the hose small enouth to insert.
