Door keys
Old May 17, 2026 | 02:46 PM
bturner425's Avatar
Default Door keys
Does the door and trunk use a different key than the round ignition key? I only got the one key and what looks like a universal remote with my new to me 2001.
Old May 17, 2026 | 03:29 PM
motorcarman's Avatar
The Driver's door, Cubby, Boot lid and Ignition all have the same 'cut' but the VALET KEY has a different key tip that will not operate the boot lid or cubby locks.
All TIBBE 8 cut KEYS will LOCK the 'tumbler' set in the door but only the correct key will UNLOCK it.(don't know about 6 cut)
The boot lid lock is seldom used by most people and when you try to use the key after a few years of NON-USE it will not work. The lock gets 'jammed-up' with corrosion and debris so you need to lubricate and work the lock to free it.
I had to spend up to 10 minutes lubing and working the key in a customer boot lid lock before I got it freed.
USE the key in the door and boot lid a few times a year or cry when it gets stuck!!!!!!!!!!!
Old May 17, 2026 | 03:31 PM
bturner425's Avatar
And this key is different than the round ignition key, which is the only one I have?
Old May 17, 2026 | 03:43 PM
barnter's Avatar
It's possible the ignition barrel has been changed.
Old May 17, 2026 | 08:13 PM
zray's Avatar
my 2002 uses one (black) key for everything.
Z
Old May 17, 2026 | 08:17 PM
zray's Avatar
^^^^ this !!!^^^^
everything on these cars needs to be used frequently or issues associated with disuse will arise.
that includes all the electronics, sounds system, and nav system if so equipped.
i didn’t use my CD changer for months (years ?) and now I’m paying the price.
Z
Old May 18, 2026 | 07:17 AM
JimmyL's Avatar
I better start using that cassette deck. ;^)
Old May 18, 2026 | 11:06 AM
bturner425's Avatar
I am going to get a cassette adapter for my iPhone Airplay.
Old May 18, 2026 | 10:33 PM
Sone's Avatar
The cars came with Tibbe keys (the "round" key you're looking at). Look at the very tip of the key -- if it goes smoothly from the tip to the first cut on the side, that's a Valet key. If there is a tiny ":ledge" profile cut between the tip and the first big cut, that's a standard key.
Valet keys open doors and work the ignition lock, but they are NOT supposed to operate glovebox or trunk.
A few moments with an appropriate tool can put the profile onto a Valet key, converting it to the standard key.
denis4x4
Sep 7, 2020 09:16 AM
dinop
Jan 17, 2016 06:55 AM
magnum454
May 23, 2014 08:58 AM
vance580
Jul 17, 2010 11:57 PM
Jocelzy
Jun 29, 2008 04:41 PM
