The dreaded ABS warning!
Old Nov 10, 2012 | 07:06 AM
mcook's Avatar
Default The dreaded ABS warning!
My ABS warning light has started to appear, together with the loss of tracking and ASC. Thing is, this only happens when the engine is warm.
First start of the car in the morning is fine, then after a short drive (15 minutes or so), when the car is started again the ABS warning appears.
The warning does not appear while driving, only when starting the warm engine.
I have checked and cleaned the wheel sensors to no avail, so I am thinking the module may be the problem. If there are bad soldered connections, then they may possibly be making/breaking as the engine compartment heats up the module.
I just wanted to run these thoughts by the forum in case anyone else has had a similar problem, and before I remove the module.
The car is a 2001 XK8 with 36,000 miles.
Thanks,
Malcolm
Old Nov 10, 2012 | 07:12 AM
steveinfrance's Avatar
I'm afraid you're likely to be correct.
Although ABS/DSC TRAC is pretty specific it is worth checking the condition of your battery.
Can you get the C codes read ? A standard OBD reader doesn't see these.
If you do decide to attack the module you don't need to disconnect the brake pipes BTW.
Old Nov 10, 2012 | 07:39 AM
mcook's Avatar
Thanks for the reply, Steve.
I would love to get the C codes read, but I live way out in the country and the nearest Jag dealer is two hours away.
I plan to remove the module tomorrow and check it out, and will post the (hopefully happy) results.
Malcolm
Old Nov 10, 2012 | 08:15 AM
Jon89's Avatar
As Steve said, check your battery first. Weak batteries create all sorts of false warning messages in these cars....
Old Nov 10, 2012 | 08:25 AM
Gus's Avatar
Gus
This link might help.
Old Nov 10, 2012 | 10:02 AM
mcook's Avatar
How do you remove the module without disconnecting the brake lines?
Old Nov 10, 2012 | 10:03 AM
Spurlee's Avatar
Default Rebuild
Rebuilds are inexpensive and durable. A lot of seemingly unrelated electrical issues went away whan I had mine professionally fixed. They did more than just resolder the connection that always goes bad.
I got a lifetime warranty which is better than OEM new. The unit comes out easily and I could drive my car for the few days it took to send/receive the unit. I didn't even have to bleed the brakes. I also like the idea of getting the same unit back as was on the car originally.
There are many places that advertise on ebay - pick one that seems professional; mine was in Idaho - ModuleMasters.
Old Nov 10, 2012 | 10:13 AM
Spurlee's Avatar
You'll have to remove the brake line fittings to slip the unit out (use a flare wrench and be careful of the fine threads and aluminum base...) and then reattach them. Reverse the process to reinstall the unit. I didn't find it necessary to bleed the system even. The pump won't cycle with the controller removed anyway.
ABS systems operate in addition to the primary braking system and can be separated without effect. I drove my car for a few days with the control unit removed.
This is a great DIY project.
Old Nov 10, 2012 | 10:16 AM
baiao's Avatar
Default Abs light
My 2001 Jaguar XK8 with 90000 miles has the ABS light on.
I have cleaned the wheel sensors , checked the battery, now going to
Jaguar Dealer to see if he can read any codes. They offered to check it
for free.
I was told it could also be the wiring harness to the wheel sensors.
Old Nov 10, 2012 | 10:30 AM
Gus's Avatar
Gus
The test procedure on my page may be different for other cars and model years but the concept is the same. When it comes to checking the connections I would clean them with contact cleaner and install di-electric grease to prevent moisture from causing additional problems. If you plan to check further on your car you can look up the onelines on my page for your car. It will provide you with the pin configuration and locations of the connections.
Old Nov 11, 2012 | 02:17 AM
Here you go
https://www.jaguarforums.com/forum/x...-repair-62539/
On another thread a Jag Tech also confirmed he happily bent the brake pipes for this task.
Old Nov 21, 2012 | 12:25 AM
bob myers's Avatar
Default module rebuild
On ebay there is a guy from cali that will rebuild the brake module for $45. I dont know if he is any good, but his feedback is.
Old Nov 21, 2012 | 12:27 AM
bob myers's Avatar
I just noticed at the bottom of the page an advert for a $59 module rebuild service.
Old Nov 21, 2012 | 05:27 AM
RJ237's Avatar
I used Module Repair Pro of Ca through ebay. It works.
bdboyle
Sep 16, 2019 05:58 PM
goges
Oct 5, 2015 04:53 PM
leep123
Sep 30, 2015 03:41 PM
Old_Doc
Sep 29, 2015 03:43 PM
