Drivers seat bracket broken?
Old Jan 5, 2014 | 02:05 PM
Windycityx's Avatar
Default Drivers seat bracket broken?
So the bracket the holds the screws in on each side has somehow broken on both sides and the front part of the seat now flies backwards from the front when I accelerate. I have no idea on how something like this is even possible, is this common? Can someone tell me a part number or how to find a replacement and how to do it?
Attached Thumbnails Drivers seat bracket broken?-unnamedlj.jpg   Drivers seat bracket broken?-unnamedl%3Bl.jpg   Drivers seat bracket broken?-unnamedass.jpg
Old Jan 5, 2014 | 03:17 PM
XKRacer's Avatar
That's a new one on me and I don't believe you would be able to buy a part like that, however a whole seat runner would be easy to get secondhand, I have a few, try a breaker
Old Jan 5, 2014 | 03:43 PM
Windycityx's Avatar
I was looking to see if someone had the part number, what its called exactly or a picture so I can look around.
Old Jan 6, 2014 | 06:59 PM
Windycityx's Avatar
Anyone have an idea on what this part is to be able to find a replacement? Thanks!
Old Jan 6, 2014 | 07:21 PM
JgaXkr's Avatar
What year & model is your car?
Old Jan 6, 2014 | 11:35 PM
Windycityx's Avatar
97' xk8
Old Jan 7, 2014 | 11:06 PM
Windycityx's Avatar
Anyone know how to figure out what this part is so I can try to find one?
Old Jan 8, 2014 | 02:54 AM
XKRacer's Avatar
Having the part no. is not going to help you much, if you can not see a way of welding the broken section back together your only option is replacement, from Jaguar they come as an assembly, no individual sections, no individual part no.
From Jaguar you are going to be looking at ALOT of money $$$, but from a breaker, I would sell mine for about $60 depending on type, having memory seats makes a difference....
If you are that keen to get the part no.s download the Jaguar Parts Catalogue, it is avialable on the forum
Old Jan 12, 2014 | 02:50 PM
steven300's Avatar
it looks fixable.strip the upholstery of seat ,and find a buddy with a mig welder and have at it.i just repaired a 71 chrysler bucket seat that i'm going to reupholster,as with anything,time and/or abuse will wear anything out...steve.
Old Nov 15, 2014 | 12:43 PM
JasonMFW's Avatar
Did you ever get this fixed? The exact same thing just happened to me tonight.
Old Mar 19, 2015 | 09:42 PM
dmo's Avatar
dmo
This just broke on my 1997 XK8, too. It seems like an odd thing to break. I don't know if it is worth trying to replace the whole seat or if I should just find someone to weld it. If it took 17 years to break, hopefully a spot weld will buy me a another 10.
Looking for a link on how to disassemble the seat - it is the drivers side memory seat.
The worst part about it is that the Spring is finally here and I can't take the car out for a spin!
Old Mar 20, 2015 | 01:45 AM
rchweidan's Avatar
The same thing happened on my 97 XK8 about a year ago. I had it welded and its held firm ever since...
Old Mar 20, 2015 | 11:02 PM
dmo's Avatar
dmo
Thanks rchweidan. I disassembled the seat, found a car guy that does his own welding, and got it fixed for free. The welded brackets are solid!
I was not able to get the control panel for the seat off so I could not completely remove the upholstery or padding. He was able to weld with everything attached with no damage, charring, or discoloration to the materials around it. If anyone knows how to remove the seat control panel on a 97 XK8, that would be good to know.
Old Mar 23, 2015 | 07:29 PM
wolfpck1's Avatar
have a drivers seat sitting in back of the house... if you can tell me how to remove the part you need maybe we can figure something out .
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Clamdigger
Sep 12, 2015 03:43 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
