Driver's seat stuck in forward position
Old Aug 29, 2020 | 01:59 AM
dwafford's Avatar
Unhappy Driver's seat stuck in forward position
Car wash guys moved both seats as far forward as possible in order to clean the back seat area, and the driver's seat is now stuck in the farthest forward position. Can't figure out how to pull the seat and work on it, because in this position the forward bolts are inaccessible. Any suggestions?
Old Aug 29, 2020 | 04:29 AM
DavidYau's Avatar
Default Bad position to be in. Can you check connectors under the seat?
Bad, bad position to be in. Before you start cutting the bolts from under neath, can you stick a mirror under neath the seat to check the connectors. If they have been bumped loose, can you reach to re connect.
pic of bottom of my seat in my 99 XK8 below.
overview
Old Aug 30, 2020 | 06:09 PM
chillyp's Avatar
FWIW - my drivers seat was stuck for a while when i purchased the car. It would not move all the way forward. There was a penny stuck on the rail. Might want to check for things on the rail, like a coin that might be preventing it from moving.
Old Aug 30, 2020 | 06:26 PM
Addicted2boost's Avatar
The probability that the seat control module under the front of your seat was crushed to some degree like they all get and stop working. The best thing to do is get a 10mm socket with a small ratchet and unbolt that module, disconnect it and swap It with the passenger side seat module so you can at least move your drivers seat.
Old Aug 30, 2020 | 08:27 PM
Johnken's Avatar
What happens when you try to move it with seat button? Do any other eat functions work?
Do you have memory buttons? Does that move her?
bad switch, bad motor, no power, obstruction? Can you describe more?
Old Aug 31, 2020 | 02:06 PM
PKWise's Avatar
dwafford,
As mentioned by addicted2boost, your best option is to swap out the controller module.
This method was successful in a previous thread....
https://www.jaguarforums.com/forum/x...orward-235452/
Scott V
Mar 21, 2020 10:38 PM
attaboy
Dec 12, 2018 09:14 AM
new mexico
May 17, 2018 02:18 PM
EJ Garity
Aug 17, 2015 12:09 AM
Andrew
Sep 30, 2012 01:51 PM
