driver's seat won't recline
Old Nov 26, 2011 | 09:06 PM
mike lomai's Avatar
Default driver's seat won't recline
the back rest of the drivers side is stuck in the forward position and it doesn't want to recline back, works forward but not backwards...what can i do?
Old Nov 26, 2011 | 09:38 PM
WhiteXKR's Avatar
Welcome to the forum!
9 times out of 10 it is worn or corroded circuit board traces at the very edge of the electronic seat control module mounted under the seat. See http://forum.roadfly.com/threads/128...8#post12849848 to repair it yourself.
Search 'seat module' and you will get lots more information in this forum, including some places to repair it if you do not want to do it yourself.
You can swap the modules between each of the two seats to confirm the problem is with the seat module.
Old Nov 27, 2011 | 10:29 AM
Reverend Sam's Avatar
To add to what WhiteXKR said, the modules are relatively easy to swap. If the seats still slide forward and backward, just slide the seats forward and loosen the two Torx bolts that hold the back edge of the seat rail down. Then slide the seats back and remove the two front bolts. Then you can tilt up the front of the seat enough to access the bolts that hold the seat modules in place. Unplug the connector(s) first. If you have the Torx bits and a ratchet you can swap the seat modules in under ten minutes.
Oh yeah... there's a plastic piece that covers the outside seat rail that has to be removed, too. It just slides forward and comes right out. It's not held in with screws or anything.
Old Nov 27, 2011 | 01:24 PM
mike lomai's Avatar
Default thanks to white xkr
thank you for that tip that was the issue.
Old Nov 27, 2011 | 01:31 PM
mike lomai's Avatar
Default updated dvd navigation
Hello looking for an updated version of the dvd navigation system cd for 2001 xk8, where to find?
Old Nov 27, 2011 | 03:10 PM
There are lots of threads on that. Just do a search. The most recent dvd you'll be able to find will be a 2003 version. The factory nav system really sucks. I new handheld Garmin is light-years ahead of the 10 year old factory system in your car.
Old May 1, 2016 | 04:18 PM
michaelbrandall's Avatar
Default what does it look like?
I'm trying to figure which one is the module. The one I thought comes up as an air nah module when I google it....
Old May 1, 2016 | 05:11 PM
avern1's Avatar
If you have a bad seat module the best route is to get in touch with Darrell Turner 858-649-9090. He repairs them and has repaired the modules on both my XK8 and XJ8.
Old Jun 10, 2018 | 09:03 PM
englishmaninla's Avatar
Would the electronic seat control module also be responsible for the front seat back not tilting forward to allow access to the rear seat? Or is the seat tilt knob purely a mechanical process?
Old Jun 10, 2018 | 10:00 PM
Well, I'm embarrassed........of course it's mechanical!
JagBrian
Aug 18, 2019 05:07 PM
Clamdigger
Sep 12, 2015 03:43 PM
wcourt3010
Sep 9, 2015 04:34 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
