electronic plug location
Old Jun 20, 2018 | 11:55 AM
wcnesta's Avatar
Default electronic plug location
Is there a manual for the 03 XKR that shows the location of the electronic plugs? I can not locate EM1-19. Trying to fix a low coolant error lite problem.
Old Jun 20, 2018 | 01:13 PM
The OG (Orange/Green) feed from the Instrument Pack is grounded via the BK (Black) to display the warning.
For circuit test purposes with the ignition ON, disconnecting the brown harness plug from the coolant sensor in the Expansion Tank should have the low coolant warning OFF. Connecting the OG to BK terminals in this harness plug should have the warning ON. If it works like this, the circuit is OK and the fault is in the sensor.
Old Jun 20, 2018 | 03:53 PM
JagV8's Avatar
Try the electrical guide / workshop manual.
Old Jun 20, 2018 | 05:12 PM
wcnesta's Avatar
Attachment 216517
Hi Graham
I replaced the sensor and have the same symptom. While checking, I shorted the sensor plug leads together with the ignition switch on, but this did not turn the lite off. Either I have a bad connection on the instrument module, a broken lead from the module to the sensor or a bad logic ground on the other side of the sensor. According to the schematic the logic ground is controlled by the ignition switch being in the on position. I am trying to find a logic ground I can tap into and wire it to the switch to see if this fixes the problem. If it doesn't then I have a bad connection or broken wire going to the module. Thanks for your input these wiring problems are a pain in the you know what!
Old Jun 21, 2018 | 11:35 AM
DevonDavid's Avatar
I'm an amateur in electrikery but could you just connect the "logic ground" side of the circuit to a "proper" ground like the battery negative terminal. If the light stays on, that would tend to suggest that it's the "instrument" side of the circuit that is faulty. If it goes off, then it's the connection to logic ground that doesn't work. I can't see why this could do any harm, or do any damage.
Old Jun 22, 2018 | 07:32 AM
wcnesta's Avatar
You have to be careful with using other types of grounding. The logic ground is applied with the ignition switch turned on. I used my VOM meter and checked the logic ground pin to make sure I was getting the ground. With the ignition switch off it is open with it on ground. I shorted the pins on the sensor plug and got rid of the low coolant message. It appears the problem is with the magnetic float.
SteveLeighton
Mar 31, 2018 11:27 PM
Ubad2
Feb 18, 2018 11:01 AM
VAXKR
Sep 11, 2017 04:25 PM
andbark
Apr 3, 2017 02:18 PM
hlgeorge
May 5, 2010 08:29 PM
