Engine Bay Paint...
Old May 13, 2011 | 05:56 PM
Jag69's Avatar
Default Engine Bay Paint...
While peering into the engine bay at the mechanic today I (once again) noticed the engine bay paint is a different and flatter green color than the Aspen Green Mica on the body.
Is this normal?
Thanks in advance.
Old May 13, 2011 | 06:15 PM
Fedoraja1's Avatar
The green in my engine bays is different on both cars. It's seen less sun, less weather, less stuff brushing against it, hitting it, chipping it etc.
Old May 13, 2011 | 07:23 PM
test point's Avatar
. . . and Jaguar did a p...s poor job of painting the engine compartment. If you were to inspect a silver XK8/R or XJ8/R engine compartment you would swear that the front end had been replaced.
Old May 13, 2011 | 08:59 PM
Spurlee's Avatar
Default Paint is intended to be that way
It IS a different paint, less expensive. At some point along the way many manufacturers started using a less expensive paint and painting process on the interior areas. Just when it occured varies, of course, by manufacturer and model.
A common "points-off" error in top level restorations is using a glossy finish in the engine bay when it should be a matte or satin finish...
My friend the 'Vette judge even takes points off for overspray that isn't present when it's supposed to be there.
Old May 13, 2011 | 09:42 PM
Fla Steve's Avatar
Yes a dull matte or satin finish is correct.
Old May 14, 2011 | 09:26 AM
RCSign's Avatar
The platinum (silver) cars the engine bay is a off white or whitish grey, I've noticed even the channels that run along the fenders are not completely clear coated. I believe the robotic paint system may be at fault for that.
Old May 14, 2011 | 03:21 PM
XKRacer's Avatar
Would you beleive they even have a paint code for it too
Old May 3, 2013 | 09:44 AM
RaceDiagnostics's Avatar
Does anyone know what the code is for platinum (silver) engine bay paint?
Old May 3, 2013 | 10:28 AM
GordoCatCar's Avatar
...................... Primer.
Old May 3, 2013 | 11:08 AM
RJ237's Avatar
I thought it was the same as the exterior paint but without clearcoat. Very interesting.
Old May 3, 2013 | 02:28 PM
I'll give Jag a call in the morning and get a code from them.
I have cleaned up this area and want to give it a blow over, you can see it looks like primer but it must be a topcoat of some kind.
Old May 4, 2013 | 05:12 AM
The paint code is JUC10
I just called my local parts store (Halfords), they said they would make up a spray can that I can pick up in 15 mins.
Old Jan 17, 2015 | 02:58 PM
frankc's Avatar
Guys you may have the answer I have been hunting all over the place for. My car is Zircon blue, a 2003 XKR, but try as I might I cannot find a code for the engine bay paint. I have even emailed Jaguar but have had no reply.
Is it a matt Zircon blue? I have tried actual Zircon paint used on the exterior but it just looks plain wrong.
Can anyone help?
Thanks!
Old Jan 18, 2015 | 05:22 AM
ArtyH's Avatar
Have you tried using a cutting compound for the rusted coloured area, just looks like its a coating of rust colour. Or you could try covering it with coca cola, one of my mechanic's swears by it.
Good luck.
Old Jan 18, 2015 | 05:46 AM
frankc's Avatar
Good luck.
I assume your not talking about my paint request.
If you want to get rid of rust there is a product from Hammerite I think they call it curerust? I tried it on my XKR and left it overnight and by the next morning it had converted it back into a more solid black metal ready to be painted over. Usually I do not promote such products but if they work well..
Still awaiting a reply regarding my paint. Is it possible to get a silk or matte finish Zircon Blue? If so does anyone have the paint code? I have it for Jag Zircon Blub but not the matte finish one.
Old Jan 18, 2015 | 08:49 AM
Originally Posted by frankc
....... Still awaiting a reply regarding my paint. Is it possible to get a silk or matte finish Zircon Blue? If so does anyone have the paint code? I have it for Jag Zircon Blub but not the matte finish one.
Surely the matt finish is achieved with 'normal' body paint followed by a satin (matt) lacquer?
On the videos I've watched of Jaguar production, the entire bodyshell is painted the same colour in one operation so the engine bay finish has to be an additional process to give the final matt appearance.
Old Jan 18, 2015 | 11:46 AM
frankc's Avatar
Just had a lot of paintwork done on my car. See Franks XKR Story. - Page 7 for details. Martin, my friendly car sprayer, always gives me left over paint. This paint has the metalic bits and shiny stuff all-in-one. He sprays stuff on top of that to protect it. I tried this paint on my engine bay and whilst it does blend in if you do individual bits. On the engine bay itself it does not look right at all. I tried dabbing some on and it did not blend in at all.
I am going to try contacting Jaguar on Monday to see if they can help. The dealership cant help me, I did ask.
Old Jan 19, 2015 | 07:28 AM
............ I am going to try contacting Jaguar on Monday to see if they can help. The dealership cant help me, I did ask.
Frank,
I've sent this question to our contact in Jaguar UK CRC (Customer Relationship Centre).
Old Jan 19, 2015 | 04:16 PM
frankc's Avatar
Frank,
Thanks Graham. I did send them an email about a week or so ago. Never got a reply. I suspect its a satin finish Zircon Blue like the exterior,but will see what your contact has to say.
Old Jan 20, 2015 | 07:15 AM
Frank,
The solution is simpler than we were all thinking. Here's the reply from Jaguar Land Rover Ltd in Coventry:
It isn't a special paint or an additional process, just leaving the guide coat without applying the clear gloss.
