Engine idling extremely rough
Old Nov 24, 2013 | 08:37 PM
Stefoo's Avatar
Default Engine idling extremely rough
2001XKR idleing irracticly and engine light is now on. I suspected the kids have put in cheap gas but it Seems to drive fine when over 1000 rpm to the supreme grade gas pump.. Anyway just got the following10 codes. 300,303,304,305,306,307,308,1316,0133,0153 and 1111. Would appreciate some starting points as it looks more serious than spark plugs however it has over 120k miles and until this week the engine was running sound. Cheers
Old Nov 24, 2013 | 08:58 PM
WhiteXKR's Avatar
Have you replaced the plastic secondary timing chain tensioners?...they were still used on most 2001s. I would not even run the engine with your mileage until you do that and verify the cams are aligned. It is possible your timing chain has skipped a tooth....one more could lead to a seriously damaged engine.
Old Nov 24, 2013 | 09:13 PM
Stefoo's Avatar
Ok thanks. I haven't changed them and do not know if previous owner did? No Maintainace record of this being done from the dealer. How do I check cam alignment or is it a dealer thing.
Old Nov 24, 2013 | 10:02 PM
WhiteXKR's Avatar
There are volumes of information on this forum regarding the secondary tensioner problem. I suggest you use the forum search.
Many members have done it on there own with the help and support of the forum. Even if this turns out not to be the root cause problem, it absolutely needs to be checked on an engine of your vintage and mileage.
Once you read some of the material, come back and ask questions.
If you do not want to do it yourself, an independent shop that services Jaguars will save you money over the dealer.
Old Nov 24, 2013 | 11:33 PM
Stefoo's Avatar
Great practical advise. My son just finished his first year apprenticeship at a dealer so I will get him involved. His been like a leech while at school so hopefully he can help pay his way on the wife's car.
Old Nov 25, 2013 | 05:49 AM
test point's Avatar
Please confirm that you understand WhiteXKR's comment;
Rough idle is a classic symptom of cam chain tooth jump. Many engines have survived jumping a single tooth, none will survive a second jump.
Old Nov 25, 2013 | 07:21 PM
Stefoo's Avatar
Working with the jag dealer on this issue. Thanks.
Old Nov 26, 2013 | 03:25 AM
............. been like a leech while at school so hopefully he can help pay his way on the wife's car.
That sounds a familiar scenario!
Best of luck in making him independent and getting the car running smoothly.
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
cissdm
May 3, 2016 06:02 AM
luc891
XE ( X760 )
Sep 15, 2015 12:30 AM
Bowman
Sep 3, 2015 03:17 PM
OkieTim
Sep 2, 2015 12:48 PM
