Engine misfire.
Old Jul 4, 2020 | 07:57 AM
Oldelance's Avatar
Default Engine misfire.
I have just replaced spark plugs, coils, fuel filter on my 2004 xk8 4.2l and have been running high octane fuel. I still notice that the car is skipping at normal operating speed , I don't notice a skip at idle. I sure could use some advice on the problem.
Old Jul 4, 2020 | 08:16 AM
George05's Avatar
Any codes ?
Old Jul 4, 2020 | 08:39 AM
NBCat's Avatar
+1 on knowing DTCs, if any.
This is posted in the wrong forum. Should be in the X100 forum if the vehicle is a 2004MY.
Old Jul 4, 2020 | 09:06 AM
Oldelance's Avatar
Originally Posted by George05
Any codes ?
no codes. Check engine light come on sporadically. When it's off I don't notice the skipp. When on I do.
Old Jul 4, 2020 | 09:46 AM
Stuart S's Avatar
Originally Posted by NBCat
... This is posted in the wrong forum. Should be in the X100 forum if the vehicle is a 2004MY.
Oldelance,
You're in the X150 Forum, for 2007-2015 XK/XKR models. You should be here: https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
Old Jul 4, 2020 | 12:54 PM
George05's Avatar
Get a code reader/scanner on it
Old Jul 5, 2020 | 11:51 AM
JagV8's Avatar
Should be codes, then. Sounds like your tool is failing to report them. They're kept AGES so they'll be there.
Also, look at the fuel trims.
Old Jul 5, 2020 | 01:24 PM
I've moved your question from X150 (2006 - 2014) to X100 (1996 - 2006) forum. This is the place to post technical questions about your 2004 XK8.
Brandon Wright
Jan 15, 2022 07:24 AM
aphorton
23
Aug 10, 2017 05:31 PM
Mooch1983
Feb 9, 2015 10:13 AM
rycymru
Aug 10, 2010 02:46 AM
mel
Feb 22, 2010 04:34 PM
