Engine noise at cold startup - 2006 XK8
Old Apr 10, 2023 | 12:14 PM
woodlandsPRO's Avatar
Default Engine noise at cold startup - 2006 XK8
Hi, all. XK8 has 48k miles. Recently, when starting with air temp below 45 degrees I'm hearing clunking noise for 5-10 seconds until oil warms up. Noise does not coincide with engine RPM. What could this be? Thanks, Richard.
Old Apr 10, 2023 | 01:23 PM
Richard,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to XK8/XKR forum. Members here with the same model will be able to help.
Old Apr 11, 2023 | 01:11 AM
Pistnbroke's Avatar
Do a video with your phone with the hood up and post it ....unless we listen it could be the wife trying to get out the trunk.
Old Apr 17, 2023 | 02:55 PM
zray's Avatar
Piston slap is common with these cars. What viscosity of oil are you using ? Is it right for your climate ? The owners manual has all that information.
Piston slap that goes away soon is not something to worry about.
Z
Old Apr 17, 2023 | 04:49 PM
Pistnbroke's Avatar
Change to 10 w 40 and you will be happy with no piston slap
Old May 10, 2023 | 11:30 AM
Thanks. Using 5/30 oil, as recommended. Houston, TX. This happens on cold start at temp below 40f.
Would piston slap noise correspond to rpm, i.e., as rpm increases, the rapidity of the knock also increases? My 2006 XK8 has a knock when cold, just started at abou47K miles. Stops in 30-60 seconds at idle. Sounds like rod knock to me but I am not a mechanic.
The water pump is only a few months old, with a new belt. I think the tensioners are ok, based on a professional opinion when I replaced the water pump.
What do you think? Richard
Old May 10, 2023 | 12:53 PM
zray's Avatar
Houston gets hot enough to use 0w-40 year round, or 5w-40 in the warmer months, as per manual recommendations for climate.
yes, when the piston moves faster, you will get more rapid piston slap. Just let the car warm up before revving the engine. That is the prudent way to go.
knocking from rod bearings typically does not go away when the motor is warm. Piston slap does.
Z
Old May 11, 2023 | 10:19 AM
Thanks. This cannot be piston slap because the rate of knocking does not change as the rpm changes. Richard
Old May 11, 2023 | 10:29 AM
zray's Avatar
Are you using a hollow hose or automotive stethoscope to isolate the knocking . Those are particularly valuable.
When a knocking goes away when the engine temp is normalized it’s almost always something in the top end, usually piston noises, followed by valve clattering.
pulley bearing noises don’t generally go away, but they can if the bearing is just beginning to fail. But that noisy occurrence is usually in the first few seconds of operation, not over an extended length of time as the motor heats up.
Best of luck in your search.
My engine has been knocking when cold for 5-6 years / 66,000 miles (ever since I’ve it). I routinely let the car warm up to at least 150 F before driving away. By that time the slapping / knocking has ceased.
Z
Jaguar XJL 2016 3.0 SUPERCHARGED
Mar 29, 2022 12:52 PM
Mar 25, 2022 05:36 PM
hen555
Feb 5, 2019 11:30 PM
cjaekl
Jan 8, 2012 12:10 PM
Prowler
May 6, 2010 02:06 PM
