Failsafe Engine Mode puzzler
Old Jun 4, 2013 | 12:47 PM
runningiron's Avatar
Default Failsafe Engine Mode puzzler
I have a 2000 XK8 with 90K miles. A while back I started getting the Failsafe Engine Mode warning. No fault code other than the standard P1111 is showing nor is there any performance degradation. I finally realized that I only get the condition when the cruise control is turned on, whether engaged or not. When the warning comes up, cruise control is turned off - or, at least, the light on the button goes off and I can't engage. Has anyone else experienced this and, if so, do you have any suggestions?
Old Jun 4, 2013 | 01:53 PM
Had this happen once (no codes as well) and it cleared have not seen since. Per JTIS there are 10 codes that will cause cruise to be inhibited:
Amber Engine Failsafe ModeCruise inhibited
P1516
P1517
P1571
P1696
P0568
P0570
P0569
P0567
P0566
P1697
Old Jun 4, 2013 | 02:26 PM
If I read the DTC chart correctly, these faults do not store the code - so you would have to read before shutting the engine off to see the fault.
Old Jun 4, 2013 | 03:45 PM
Gus's Avatar
Gus
If it is showing up only when the cruise control is turned on I would be looking at the brake switch. It has two switches and one of them is for the cruise control.
Old Jun 4, 2013 | 09:51 PM
Gus, thank you for the heads up. I'll check that next. It does seem to come on right after I've slowed or otherwise heat the brakes.
Old Jun 5, 2013 | 03:09 AM
steveinfrance's Avatar
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
As Gus says there's lots of threads on the brake switch/cruise control problem.
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
scottatl
Sep 4, 2015 08:08 PM
OkieTim
Sep 2, 2015 12:48 PM
