Fan removal without draininng the engine?
Old Sep 25, 2016 | 07:45 AM
RaceDiagnostics's Avatar
Default Fan removal without draininng the engine?
I'm having trouble with the serpentine belt tensioner bolt, its rounded off so I will need to take out the fans to get better access.
The workshop manual says drain the coolant and remove hoses, however I thought I would check here first to see if anyone had done this without draining the coolant?
Old Sep 25, 2016 | 09:37 AM
Well this job just gets worse, the right hand side fan retaining nut is just spinning so I will need to remove the upper hose to get access to cut it off.
So next question on the fan housing, I can see two nuts retaining the housing, one at each side at the top. Is there just the two?
Old Sep 25, 2016 | 09:51 AM
Gus's Avatar
Gus
That is the way it was on my car. Did you try to put a shim to hold the bolt from the back?
Gus
www.jagrepair.com
Old Sep 25, 2016 | 10:27 AM
Johnken's Avatar
Agreed. 2 nuts, like Gus said watch the bolts sticking out. They are not secure once you remove the nuts (I lost one once).
You need to put hood in service position. disconnect the upper radiator hose. Remove nuts. Disconnect the two fan electric connections from the motor and the wire clips on fan body. Tilt fan forward. Lift upwards and out.
John
Old Sep 25, 2016 | 10:42 AM
test point's Avatar
It appears that only the upper hose is in the way of removing the fans. If you have a small hand pump you could suck the coolant below the thermostat and not have to drain the entire system.
Multi-Use Transfer Pump
Old Sep 25, 2016 | 11:07 AM
Johnken's Avatar
Good idea about pump. Don't forget you are only going to lose a small amount of coolant if the hose is just disconnected from the radiator side and pushed vertical while you are working.
Probably enough to concern you if you have a dog though. I'll never forget how poisonous it is yet they say it takes great (being serious not funny subject).
John
Old Sep 25, 2016 | 11:25 AM
I'll drain out a bit using a turkey baster as my hand pump is full of diff oil.
Old Sep 25, 2016 | 11:39 AM
Johnken's Avatar
RD, sounds good. It will take about 5 minutes over all. Hey, an idea for you. After I lost one of those screws, I decided to squirt some Goop brand glue into the slot that holds the screw. Now it can't fall out and the Goop is like silicon - you can remove the screw if you want to someday.
remember that the top of the fan is flush, no gap, with top of radiator. Easy to miss align on reinstall.
Good luck with it.
John
Old Sep 25, 2016 | 10:01 PM
Dr. D's Avatar
Howdy Folks:
FWIW, I made this double ended tool to remove both belts without undoing the coolant hose connection. (I did have to figure rotation and height of the square before cutting the square hole and welding since there is so little clearance. I used 3/16 X 2 barstock)
Attached Thumbnails Fan removal without draininng the engine?-20160510_124453.jpg   Fan removal without draininng the engine?-20160510_124620.jpg
Old Sep 26, 2016 | 04:15 PM
I made up a similar tool to release the tensioner but there wasn't enough space to get it on the bolt without bending the fans even with a special shallow socket.
I managed to get a hack saw blade in to cut off the spinning nut once the top hose was off.
Fans out, the hood was just in the normal open position.
Then there was plenty room.
Cracked off no problem in the end with a 6 point OTS.
Old Sep 26, 2016 | 07:55 PM
Gus's Avatar
Gus
I am surprised that you had to pull the fans on your car. I replaced the tensioner, idler and water pump without pulling the fans. I guess a difference between years.
Old Sep 26, 2016 | 08:17 PM
I think if I had a long 6 point 13mm spanner I could have done it, but my 12 point rounded off the tensioner bolt and I didn't want to make it any worse so opted to get the space for a 6 point socket.
Old Sep 26, 2016 | 08:32 PM
Gus's Avatar
Gus
Always an opportunity!
Old Oct 1, 2016 | 02:44 PM
Well that's it done, the car has been off the road for most of the last 3 months, I have spent at least 80 hours working on repairs, maybe more.
The last job today was to refit the fans and rad top hose.
As one of the captive bolts spun in the plastic housing on removal and had to be cut off, I needed to modify the replacement to allow reassembly.
Here are the original bolts and replacement.
Welded the new bolt to some 2mm plate.
Cut it off and cleaned it up.
In place ready to accept the fan unit.
Once all buttoned up I started it up and took it for a very short run (MOT and tax has expired) and all was well! Mot booked for next week.
It started off with a quick look underneath to see if any maintenance was needed........
Replaced lower steering column to tighten up steering response.
Replaced both rear suspension sub-frame to body brackets due to rust.
Replaced driver door catch due to cosmetic wear.
Refurbed all four road wheels due to kerbing.
Refurbished both front brake callipers, new pistons and seals, routine maintenance.
Cut out and welded in new front seatbelt anchor plates on both sides due to rust.
RH suspension turret, cut out rust and made good.
RH wing support bracket, cut out rust and made good.
RH wheel arch to floor panel, cut out rust and made good.
Front cross brace, media blasted and painted, routine maintenance.
New front brake pads, LH and RH, routine maintenance.
New rear tyres, routine maintenance.
LH & RH inner sill lip up to floor panel stripped back to bare metal and repainted, routine maintenance.
Manufactured stainless steel washers for the front upper arm poly bush set, improvement.
Stripped out old front upper arm poly bush set and replaced with new improved design, improvement.
Refurbished driver seat bolster due to wear.
Fitted replacement catalytic converter.
Fitted new serpentine belt.
What a marathon!
Old Oct 1, 2016 | 03:53 PM
NBCat's Avatar
Very good idea with adding the 2mm plate to the captive stud. Anti-seize compound would help so you never need to remove the nut again!
Seems like quite a bit of corrosion on many of the parts nearby. How strict is the MOT inspection with corrosion?
Old Oct 1, 2016 | 04:04 PM
Yes, I smothered it with copper grease before final fitting. Surface rust is no issue at the MOT, any structural member or any member within 30cm of a suspension point that has its strength compromised by corrosion is an automatic fail.
dhvoorhees
May 14, 2018 07:22 PM
hiltoncam
Sep 30, 2016 12:54 AM
radiatn
Sep 26, 2016 09:39 PM
StellaLunaGardens
Sep 21, 2016 09:51 PM
