Fast clicking noise?
Old Nov 8, 2014 | 11:23 AM
Loxmth's Avatar
Default Fast clicking noise?
Got a fast paced clicking coming from what sounds like the fuse box panel in the dash. Only hear it when I open the door. Might be under the hood,driver side near the front of the door. Doesn't hamper performance or driving. What might it be?
Old Nov 8, 2014 | 11:39 AM
WhiteXKR's Avatar
Sounds like the Purge valve valve. It is in the driver's side fender above the wheel well. It is normal for it to fast click...nothing to worry about unless it is so loud you hear it while you are driving or you have an EVAP fault code.
Old Nov 8, 2014 | 01:57 PM
RJ237's Avatar
My XJ6 had that sound when I opened one of the rear doors. Turned out to be the relay for the puddle lamp. Next time you hear it look at the bottom of the door and see if the red light is working.
Old Nov 8, 2014 | 01:59 PM
Loxmth's Avatar
Originally Posted by WhiteXKR
Sounds like the EGR valve. It is in the driver's side fender above the wheel well. It is normal for it to fast click...nothing to worry about unless it is so loud you hear it while you are driving or you have an EGR fault code.
Thank you sir. Sounds like you nailed it. No codes so I'll keep on driving.
Old Nov 8, 2014 | 03:21 PM
motorcarman's Avatar
Doesn't anyone read TSBs in the large file download area???????????????
Jaguar addressed this fault 10 years ago. See TSB 303-62am for info.
bob gauff
File Type: pdf
Old Nov 8, 2014 | 03:53 PM
WhiteXKR's Avatar
Sorry...I was thinking purge valve (that what I gave the location of) and I accidentally wrote EGR valve. Must have been still half asleep. You would have an EVAP fault code if there was a real problem unless the noise bothers you. I corrected my post.
Old Nov 8, 2014 | 04:50 PM
Loxmth's Avatar
bob gauff
I only hear it when idling with the drivers door open when getting in or out of the car. Never while driving.
Old Nov 12, 2014 | 12:43 AM
Autobahn kid's Avatar
deleted double posted
Old Nov 12, 2014 | 12:44 AM
Being that the purge valve is part of the emmisions system is the replacement indicated on the TSB still covered by warranty?
hoodun
Nov 20, 2022 02:35 PM
flyrr100
Mar 14, 2016 06:37 AM
santer
Sep 25, 2015 03:28 PM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
raulan
Sep 10, 2015 12:43 PM
