Fault code P1796, Jaguar XKR 1999
Old Jan 20, 2021 | 05:36 AM
Sören Hallberg's Avatar
Default Fault code P1796, Jaguar XKR 1999
On a long journey, a red warning light suddenly came on and the text "Restricted performance" appeared. I stopped, restarted the engine and everything was fine. Later, the same thing happened, and the warning comes sooner, now after a couple of minutes. The car runs as it should, but the speed is limited to 140 km/h, 85 miles/h.
A Jaguar workshop read the fault codes, and these were:
ABS C1095, U2012
Climate control B1861, U1263
Instrument U1250, U1261, B1238
Engine P1796
The workshop said that it is a connector fault in the cable harness that gives all these fault codes. They are willing to take the car in and search but can of course not give a cost estimate. They charge £ 200 / hour. Unknown number of hours plus repair cost.........
The battery is changed to a new one and charging is ok.
Has anyone come across something similar and can suggest where to start looking?
Old Jan 20, 2021 | 08:26 AM
Originally Posted by Sören Hallberg
..... They are willing to take the car in and search but can of course not give a cost estimate. They charge £ 200 / hour. Unknown number of hours plus repair cost.......
Welcome to the forums Sören Hallberg,
I'll bet they would be very happy to spend your money like that.
Now you have the codes, finding the possible causes is not difficult. Do you want to troubleshoot this yourself?
Old Jan 20, 2021 | 08:37 AM
I'm pushed for time this afternoon but here's the possible causes for most of your list:
P1796 is the reason the vehicle keeps going into "limp home" mode.
Old Jan 20, 2021 | 08:45 AM
motorcarman's Avatar
Info for you.
File Type: pdf
File Type: pdf
File Type: pdf
BDuncan
Sep 4, 2021 07:52 AM
ooblick
Sep 19, 2019 11:32 AM
patrickw813
Jul 31, 2019 08:57 PM
dhog4n
Oct 11, 2014 11:29 AM
vettegood
Apr 14, 2012 11:52 AM
