Figured out that 18 pin phone connector for Bluetooth install
Old Nov 22, 2016 | 06:30 PM
Julian Black's Avatar
Default Figured out that 18 pin phone connector for Bluetooth install
Old Nov 23, 2016 | 04:55 PM
An extra bit I found out, by accident was that this connector has an extra "accessory on" wire. Its on the bottom row under the 12v switched and the mute wire. This "accessory on" is only active when the engine is running, and turns off with engine. I found the old Nexxia SOT-126 uses this wire, instead of the 12 switched. So whatever is using that wire only works with engine on. Just in case anyone wants to adjust theirs.
Old Nov 27, 2016 | 03:12 PM
stevepaa's Avatar
The pin outs and connector do change depending upon the year. There are many threads on this.
Old Nov 28, 2016 | 02:50 AM
They do and I've posted this summary about the earlier 10-Way and 14-Way ones a few times.
Worth adding again and putting a link to this thread in the FAQ 'HOW TO' thread so we have all the information in one place.
https://www.jaguarforums.com/forum/x...ts-data-29800/
It's under Factory Phone.
Attached Thumbnails Figured out that 18 pin phone connector for Bluetooth install-telephone.jpg
Old Nov 28, 2016 | 11:41 AM
stevepaa's Avatar
maybe add this
File Type: xls
Old Apr 15, 2018 | 06:44 PM
robot808's Avatar
Default 2001 jaguar xk8 coupe connector
Anybody able to help decipher these? I'm trying to power an aftermarket Bluetooth system with 12V ignition switched power and a clean ground, but can't seem to match up the pins on these connectors to any charts I can find.
Thank you for any help!
Old Apr 15, 2018 | 07:02 PM
robot808's Avatar
Default Left side
Old Apr 15, 2018 | 11:15 PM
rothwell's Avatar
The attached Electrical Guide for your car might help.
XK8 Electrical Guide - 2001MY.pdf
Old Apr 16, 2018 | 03:11 AM
dibbit's Avatar
If you are looking for the phone connector that this thread is about, then that isn't it.
If your car doesn't have the OEM phone kit, the yellow connector won't be connected to anything. If it does have the phone kit, it will be plugged in to another flying connector (not plugged into a module). The wire colours you want are as described at the start of this thread.
