Finally called time on my rusty cat.
Old Sep 17, 2016 | 03:47 PM
RaceDiagnostics's Avatar
Default Finally called time on my rusty cat.
No, not the car, just the catalytic converter.
I've welded it up time and time again but this time I decided to remove it to do a proper job, but after getting it off I decided to scrap it as its just too far gone.
I have a second hand unit heading to me now for £100 as there are no aftermarket off the shelf units available in the UK and the OEM is £1700!
Anyway, two of the mounting nuts had dissolved and had to be cut off, I couldn't believe how little there was left of the one on the right. The bracket on the other side was almost completely gone too.
Anyone know what the part numbers are for these nuts, I'm guessing they are not standard nuts.
Old Sep 17, 2016 | 07:03 PM
80sRule's Avatar
I bought the studs for the catalyst and then matched them at the hardware store. Here's the part number for the stud listed for the 4.2: C2N1851. I don't see a part number for the nut.
Old Sep 17, 2016 | 11:11 PM
Jandreu's Avatar
RD whoever the PO was that soaked your Cat in the Alantic Ocean needs to be bitch slapped!
Old Sep 19, 2016 | 09:52 AM
phanc60844's Avatar
'I have a second hand unit heading to me now for £100 as there are no aftermarket off the shelf units available in the UK and the OEM is £1700!'
ebay £126 new, type approved
Old Sep 19, 2016 | 11:59 AM
Where is the link?
Old Sep 19, 2016 | 12:05 PM
phanc60844's Avatar
mmm, you could always go to ebay and type in xk8 cat, that brings up loads however just for you , here's another at just over £120,
BAR90848 2676 CATALYTIC CONVERTER/CAT FOR JAGUAR XK 8 4.0 03/1996- 02/2001 | eBay
Old Sep 19, 2016 | 12:08 PM
phanc60844's Avatar
mind you , that one says it only fits the coupe, this one is for £126 and does fit the convertible
3192 CATAYLYTIC CONVERTER / CAT FOR JAGUAR XK 8 4.0 1996-2005 | eBay
Old Sep 19, 2016 | 12:46 PM
Unfortunately that is for a 4.0 and wont fit the 4.2. Any for the 4.2 say not California, so not confident to import to the UK only to find out they won't pass our MOT test.
Old Sep 19, 2016 | 02:36 PM
phanc60844's Avatar
Ops, I'd assumed that with the level of rot you have encountered that it was in the range 96-98 ish. 2002? perhaps you were right when you said that the XK8 is the worst rusting car of the modern era
Old Sep 20, 2016 | 12:49 PM
I ended up buying this set for a price close to a single stud from Jag.
MANIFOLD STUDS M10 x 40MM x 1.5mm 4.6 GRADE + COPPER FLASHED NUT CP018 5 OF EACH | eBay
Old Sep 27, 2016 | 05:00 PM
I picked up a cat from a car breaker, £80.
New and old.
Broken studs...
Welded on a nut.
Two nuts on the other stud as there was a bit of thread.
All clear!
Cleaned out the threads
And ready to go back on.
Old Sep 27, 2016 | 05:14 PM
michaelh's Avatar
RD - you make these jobs look easy
A little OT, but, out of curiosity, do you know what the advantage is of using studs rather than set bolts & nuts? There looks to be room on the back to manoeuvre.
The down pipe on my daughter's Pinin had the same arrangement and there was plenty of room for a nut & bolt. In the end I let the exhaust co. do the job as I didn't want to shear off the studs and have to remove the whole exhaust to fix.
Thanks,
Mike
Old Sep 27, 2016 | 07:11 PM
Gus's Avatar
Gus
Always enjoy seeing your work.
Old Sep 29, 2016 | 02:43 AM
This is the first example of rusting where my experience has been the same as yours.
The cats on my X308 and two XK8's were both similarly corroded. The X308 ones had to be replaced as did the 2001 XK8. I sold the 2005 XK8 before it went that far. If members in other countries aren't finding the same thing then it must be the rain and road salt that does it in the UK.
As to fixing studs/nuts, I ALWAYS renew them as appropriate whenever a manifold or part of the exhaust system is dismantled. They are inevitably seized, take ages to remove and rarely suitable for re-use.
Old Sep 29, 2016 | 06:56 AM
Thanks,
Mike
I can only assume its for ease of assembly but don't know for sure.
Old Sep 29, 2016 | 02:27 PM
michaelh's Avatar
Thanks, RD.
The mfr. isn't going to give a hoot about the next man in, I guess.
iownme
Sep 27, 2016 05:59 AM
Uncle Fishbits
Sep 17, 2016 11:41 AM
L80ous
Sep 16, 2016 11:36 AM
AllblueACR
Sep 14, 2016 12:15 PM
MikeofBonsall
Sep 14, 2016 07:12 AM
