Ford Keyfobs work!
Old Mar 8, 2016 | 06:51 AM
lilfreddie's Avatar
Default Ford Keyfobs work!
I just wanted to let everyone know that the inexpensive Ford Keyfobs work on our cars. I typed the fcc number on eBay was looking for a replacement and the Ford set came up super cheap so I tried them and they work.
Old Mar 8, 2016 | 08:02 AM
scardini1's Avatar
Thanks Freddie. Make sure you post this info in the "Non-OEM Interchangeable Parts" thread.
Old Mar 8, 2016 | 09:37 AM
Ungn's Avatar
XK8's have different remotes after 2000/2001. So these work on a '99 XK8?
Old Mar 8, 2016 | 12:14 PM
dr.fixit's Avatar
How do I find the FCC number ? I have a 1999 XK8 manufactured in late 1999, but do not have an existing fob
Last edited by dr.fixit; Mar 8, 2016 at 03:07 PM. Reason: left out part of question
Old Mar 8, 2016 | 02:59 PM
test point's Avatar
The ID is embossed on the back of the fob case. My '02 fob ID is CWTWB1U322.
The eBay search turns up lots of FordMoCo compatible devices. For $8.88 a pair shipped it might be worth a try . . . but I have two.
You won't get a growler on these.
Old Mar 8, 2016 | 05:59 PM
rdwalker's Avatar
Related question:
I hate the way the dangling alarm remote jams between my knee and the dashboard of my 2000 XK8. I always need to make sure to push it out of the way, otherwise it impairs my braking.
Did anyone find a key with a built-in remote in the head of the key, that would fit the early XK8 series?
TIA, Robert.
Old Mar 8, 2016 | 06:51 PM
Ungn's Avatar
The Early remote FCC number is K8597T315.
I think the early cars are out of luick.
Old Mar 8, 2016 | 07:10 PM
White Bear's Avatar
rdwalker
There was a thread not long ago that described modifying the old key using a later model flooding key fob, and introducing the old key into the later fob. It required the removal of the transponder from the old key, thereby destroying it, but if done properly you end up with a folding key fob.
Here you go...
https://www.jaguarforums.com/forum/x...ictures-93167/
Regards,
Old Mar 8, 2016 | 09:02 PM
BlackKat's Avatar
Haha yes. I've been using my old 2001 ford escapes key fob on the xjr. You try lincoln if you wanna get fancy.
Old Mar 8, 2016 | 09:18 PM
OhWhatNow's Avatar
I thought they would after scrutinizing my mother-in-law's Grand Marquis fob,and you may be able to swap the guts into the Jag fob to keep the growler. Haven't tried it yet though.
Old Mar 9, 2016 | 05:09 AM
JonWat's Avatar
The rubber buttons will fit the Jag fob, I bought one of these as my buttons were wearing thin.
Old Mar 9, 2016 | 06:39 AM
rdwalker's Avatar
Originally Posted by White Bear
...a thread not long ago that described modifying the old key using a later model flooding key fob...
Regards,
Thanks for the find! Robert
Old Mar 9, 2016 | 12:24 PM
Ungn's Avatar
If your current remote is a FCC CWTWB1U322, the Key mod will work.
If your current remote is a FCC K8597T315, the Key mod won't work.
Old Mar 10, 2016 | 07:28 AM
reb1999's Avatar
Just order a set for my '99 XK8 for $ 8.88 ebay with free shipping. Thanks again Rich
Old Mar 10, 2016 | 09:03 AM
Ungn's Avatar
Those should not work on a 1999.
Let us know if they do.
Old Mar 11, 2016 | 01:01 PM
magnum454's Avatar
That K number is on my remote, will the Ford fob work on a 2000XK8?
Old Mar 11, 2016 | 01:22 PM
Ungn's Avatar
From all I've seen/read it shouldn't work.
Old Mar 12, 2016 | 06:26 AM
reb1999's Avatar
Default Fob
Yes, my fob has the 7t315 code. I thought someone here said they would?? Oh well, $ 8.88 out the window... Thanks for the info. Rich
Old Oct 15, 2024 | 02:26 PM
Splerk45's Avatar
After some sleuthing, here is the likely SLM cutover VIN. The later SLM goes for about $150 USD on eBay. The earlier ones are about half that.
So if you have an earlier SLM, you could spend $150 on an SLM so you can use a pair of $8 Fobs.
EARLY KEY FOB
SLM LNC2600HE 812317-F20644
SLM LNC2600HF 812317-F20644
CHEAP FORD KEY FOBS CWTWB1U311
SLM LNG2600HB F20645-F59525
Source: https://partsfan.com/jaguar/ww
Old Oct 15, 2024 | 02:32 PM
Splerk45's Avatar
^ Sorry! Thought I was in the X308 forum. Those are X308 VINs. I will re-post the info there.
frontrunning
Aug 9, 2016 01:54 AM
Mac Allan
Feb 27, 2016 08:16 PM
f_in_seattle
Feb 13, 2016 06:06 AM
JCHouston
Feb 12, 2016 11:08 PM
Mr G
Feb 12, 2016 01:49 PM
