FPR Out of Stock!
Old Apr 10, 2014 | 12:59 PM
Spurlee's Avatar
Default FPR Out of Stock!
I'm needing a fuel pressure regulator - again - for my 2000 XK8.
STANDARD MOTOR PRODUCTS Part # PR472
Rock Auto says they are out of stock as do several other places. Is this becoming a hard to find item?
It looks like $129 is the best price, some places list it at $225 or more. I really hope I don't have to pay that!
My last one only lasted 4 years, the O rings sent bad. I replaced them but still have fuel delivery problems. I suspect the internal diaphragm went bad also.
If anyone has bought one priced right recently please let me know where.
Thanks!
Old Apr 10, 2014 | 01:49 PM
Jon89's Avatar
Do you suspect ethanol in your gasoline to be the culprit, eating up the rubber components prematurely?
Old Apr 10, 2014 | 02:00 PM
Doug's Avatar
Suspect is one thing, but how can it be confirmed?
Old Apr 10, 2014 | 02:04 PM
Jon89's Avatar
Good question. That's why I chose the word "suspect"....
Old Apr 10, 2014 | 04:53 PM
mjlaris's Avatar
That's why I buy Valero gas whenever possible. They're the only chain gas station that sells real gas, not gasohol.
Mark
Old Apr 10, 2014 | 07:35 PM
Spurlee's Avatar
Default Ethanol
All,
Ethanol WILL definitely wreck rubber parts.
I rebuild carburetors for a living and see the effects of ethanol daily. I never, ever, put ethanol in anything. There is no doubt about it whatsoever, the stuff will harden rubber and create all sorts of problems. I only use premium non-ethanol fuel.
That said, the 2 "O" rings on the FPR are hardened just like they had seen ethanol. They completely lost their seal and fuel was spraying out of the FPR back as far as the firewall.
I replaced them and still have fuel delivery issues so I presume the internals to the FPR are hardened as well.
At about noon Rock Auto took the listing for the FPR off their website. Not a good sign!
Old Apr 10, 2014 | 08:59 PM
plums's Avatar
Perhaps SMP built the units with rubber instead of viton.
If a bunch of brands are out of stock, it would mean the one manufacturer they are
all rebranding has stopped making it.
The way out then would be an aftermarket adjustable FPR as used by tuners.
Old Apr 10, 2014 | 10:33 PM
Doug's Avatar
I promise to remain silent. I promise to remain silent. I promise to remain silent
Old Apr 11, 2014 | 06:14 AM
Spurlee's Avatar
[QUOTE=Doug;951917]I promise to remain silent. I promise to remain silent. I promise to remain silent QUOTE]
Silent about what?
O'Reillys is out of stock on that part number and Autozone says they don't have it at their hubs but can order it directly - I bet it will be out of stock wherever that is. Both of these guys sell it in the $140-$150 range. I'll check a couple of other places today.
I would absolutely bet that the O rings and internal parts are not Viton. Way to go guys.
Old Apr 11, 2014 | 06:26 AM
Stumpy's Avatar
Is this the correct part?
Says in stock
PR472 Jaguar Vanden Plas Fuel Pressure Regulator NCA3007CA NCA5203EA JLM21358 | eBay
Old Apr 11, 2014 | 07:04 AM
Spurlee's Avatar
Originally Posted by Stumpy
Indeed it is! You are better at hunting on eBay than I am.
Thanks!
Old Apr 11, 2014 | 08:28 AM
Doug's Avatar
[QUOTE=Spurlee;952070]
Silent about what?
The great ethanol debate
Old Apr 11, 2014 | 08:48 AM
Paul Pavlik's Avatar
Ethanol Sucks Big time!
I'm 90% sure that Ethanol Gas caused both of my Fuel Pumps to fail during Winter Storage several years ago.
Also gives 10% Poorer Gas Mileage.
Unfortunately, Non-Ethanol Gas is not available locally.
hoodun
Feb 20, 2023 05:52 AM
Johnken
Apr 8, 2018 10:21 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
