Front brake pad replacement (2002 XK8)
Old Jul 6, 2014 | 07:56 PM
JCam's Avatar
Default Front brake pad replacement (2002 XK8)
The front brake pads on my wife's 2002 XK8 need to be replaced and I would like to know which pads to use. I have a tendency to buy the most expensive items thinking they are the best. Can you guys direct me to the best brake pads for this car?
Thanks in advance,
Jamie
Old Jul 6, 2014 | 08:10 PM
TreVoRTasmin's Avatar
I'm a fan of Akabono pads, not the cheapest, not the best stopping, not the most fade resistant out there but they are good quality, low dust, low noise, very predictable stopping with some light fading (if you're tracking it but in most cars the fluid will give out before these pads do) plus they have a decent life. Have them all around on both our XJR and XK8 and will replace them in kind.
Old Jul 6, 2014 | 08:14 PM
JCam's Avatar
Thanks TVRT for the quick reply. The current pads stop well and have never been noisy. This is not a track car and is driven by the wife. I am looking for quite stopping power.
Old Jul 6, 2014 | 08:19 PM
You'll be happen. Biggest thing I like about them is the lack of visable dust. These should be them, you can get them cheaper via ebay from time to time.
Amazon.com: Akebono EUR394A EURO Ultra-Premium Ceramic Brake Pad Set: Automotive Amazon.com: Akebono EUR394A EURO Ultra-Premium Ceramic Brake Pad Set: Automotive
Old Jul 7, 2014 | 01:42 PM
H20boy's Avatar
+1 on the Akebono's above. I've got them on my xk8 and my superv8. They perform great on both of them (of course the brembos make a little difference on the super)
Old Jul 7, 2014 | 02:12 PM
Jon89's Avatar
I like the Wagner ThermoQuiet semi-metallic pads. I have them on my S-Type and I'll be putting a set on my wife's XK8 when her front pads give up the ghost (probably this coming autumn or winter). Already purchased them from rockauto.com and they're sitting on one of my garage shelves until needed. They are quiet as a tomb, have better grab and therefore stop more quickly than most ceramic pads, generate very little brake dust, come with a lifetime warranty, and if you purchase them using the usually-available Wagner rebate they cost about one-fourth of what the typical Akebono pads do....
Old Jul 10, 2014 | 08:22 AM
JCam's Avatar
Can someone provide me with the minimum spec for the factory rotors? The car only has 23k miles and the pads still have a bit of life (just started a slight squeak). It is in the shop this morning and I am being told that the rotors need to be turned and that the shop does not know the minimum spec the rotors can be turned too. The shop is trying to go by specs provided from a set of rotors provided by NAPA.
Please advise,
Thank you in advance.
Jamie
Old Jul 10, 2014 | 11:24 AM
rothwell's Avatar
Please advise,
Jamie
The original rotors should have the spec stamped on them. ??
Old Jul 10, 2014 | 12:14 PM
JCam's Avatar
I had the shop check and only a part number could be found on the rotor. I am going to install the new rotors to guarantee the wife's car will stop without any issues. Better safe than sorry for a few hundred bucks.
Thanks for the replies.
Jamie
Old Jul 10, 2014 | 01:14 PM
danand's Avatar
I agree, these are the lowest dust pads available! Wheels stay remarkably clean.
BrentGardner
29
Dec 16, 2024 12:13 AM
ronald4313jm
Aug 31, 2015 07:58 AM
nelsonht
Aug 30, 2015 06:01 AM
Rhett
Aug 28, 2015 11:30 PM
roumor
Aug 28, 2015 01:02 PM
