Front Rotor Will Not Come Off - RESOLVED
Old 04-27-2015, 12:56 PM
R3Wood's Avatar
Default Front Rotor Will Not Come Off - RESOLVED
Hello,
I just did the rear brakes and rotors on my XKR, it went smooth.
Now I'm on the Drivers side, caliper is off, but the rotor is stuck on. I have PB Blastered it, beat on it (lightly) and it is still stuck on. This has gone on for a good 45 min.
Am I missing something? I remember my wife's Lexus had a threaded hole to put a bolt in and pop the rotor off. But I see nothing on the XKR.
Thanks in advance.
Last edited by GGG; 04-30-2015 at 04:09 AM. Reason: add "RESOLVED" to thread title
Old 04-27-2015, 01:45 PM
Stuart S's Avatar
Received 6,168 Likes on 3,393 Posts
You're in the 2007-up (alloy body) X150 forum. You need to repost in the X100 forum for your 2003, or hopefully the moderator will move your thread.
Old 04-27-2015, 04:03 PM
Cee Jay's Avatar
Received 5,181 Likes on 3,104 Posts
Seems you will have to destroy your current rotor, but you were going to replace them anyway, right? This is on an X-Type, but same deal....
jaghelp.com: Changing the front brake pads and rotors on your Jaguar X-type (2001 - 2005)
R3Wood (04-28-2015)
Old 04-28-2015, 07:45 AM
R3Wood's Avatar
Sorry, my mistake. I was in the middle of the brakes when I posted and did in a hurry
Old 04-28-2015, 07:46 AM
R3Wood's Avatar
I posted in the wrong place, but thanks. You were right, I had to beat the heck out of it and also hit it with heat . It finally came off this morning. I appreciate it. And again, sorry for posting in the wrong spot.
Old 04-28-2015, 09:24 AM
wolfpck1's Avatar
just a thought to try sometime ...after removing the caliper re install the tire and place both feet on the edges and rock the rotor loose like trying to loosen a stuck tire may give enough torque to break it loose ?
R3Wood (04-28-2015)
Old 04-28-2015, 01:07 PM
jamdmyers's Avatar
Too late for you but:
Wedge a socket extension or re-bar between the frame and the rotor, turn wheel to get it to hold, start car and then turn steering wheel to pop it.. works for rotors and bearings... Every time.
The following 2 users liked this post by jamdmyers:
jjgreer2002 (07-04-2015), R3Wood (04-30-2015)
Old 04-28-2015, 01:11 PM
DpezXK8's Avatar
Figured he just needed more incentive. I have a 2" Dia. x 6" long piece of brass I use to tap mine off with. Start with a rubber mallet and if that doesn't work just step it up a little. Of course I also rotate the rotor as I tap as not to **** it on the hub.
R3Wood (04-30-2015)
Old 04-28-2015, 03:02 PM
Jon89's Avatar
Received 4,291 Likes on 2,818 Posts
When Wayne and I replaced the two rear shocks on my wife's 2006 XK8 last October, we pounded the hell out of the rotors with a rubber mallet. No success. So we stepped up to a hammer. Still no movement. Wayne had to go after them with an air-powered impact tool (hammering on a piece of flatiron laid across the rotor) to finally knock them loose. No rotor damage at all but we were both shaking our heads at how much time and effort we had to spend getting the rotors off so we could move ahead to the next step of the project....
R3Wood (04-30-2015)
Old 04-28-2015, 03:32 PM
Cmj Lgg's Avatar
Did I read recently that someone recommended loosening the lug nuts and rolling the car??
Old 04-28-2015, 07:58 PM
cjd777's Avatar
Received 1,323 Likes on 735 Posts
No, but I heard driving it off a 4 story parking garage will do it every time, just loosen the lugs first. Oh, one trick is to weigh the back of the car so it hits on all four.
Don't know who invented anti seize, but Jag and BMW owners sure do thank you.
Wayne
The following 2 users liked this post by cjd777:
Jon89 (04-29-2015), R3Wood (04-30-2015)
Old 04-29-2015, 07:26 PM
tberry6686's Avatar
I had a similar problem when I replaced my disks and pads. Easy method is to use 2 nuts and bolts through the caliper carrier mounting points and tighten them a bit then slacken, turn the rotor a bit and re-tighten then repeat until rotor comes free. No need for heat, hammers, levers etc.
The bolts push the rotor off a little at a time so only scratch the surface of the rotor a little in case you want to re-use them.
R3Wood (04-30-2015)
Old 04-30-2015, 04:12 AM
GGG is offline
Received 16,820 Likes on 12,177 Posts
Originally Posted by R3Wood
....... I'm on the Drivers side, caliper is off, but the rotor is stuck on. ........
I've added RESOLVED to your thread title to help others searching for the solution in future.
Although it seems alien to whack your Jaguar with a heavy hammer, plenty of members agree this is the only way!
R3Wood (04-30-2015)
Old 04-30-2015, 07:13 AM
R3Wood's Avatar
Thank you for the replies. I appreciate it. The only bummer is the terrible "squeal" is the same. So I am at a loss to what could be making the noise. It usually happens after a long drive, when the weather is warm. The old pads had plenty of meat, the rotors looked good, but I had no idea as to the quality of the pads. They created a ton of dust in the front. So with the squeal I decided to upgrade to the EBC Red Stuff with EBC USR Slotted rotors.
Old 04-30-2015, 07:14 AM
R3Wood's Avatar
I agree Graham, but even with PB Blaster and heat, it would not budge. The right thing to do, is put anti-seize for the next guy . Which is what I did.
Old 05-24-2016, 09:24 PM
razorboy's Avatar
I was going to post and make myself look stupid as to why I cannot get the front rotors off my 2003 XK8.
Thank the lord for the search engine.......lol
I like the bolt idea through the original caliper mounts.
Don't know if I have that size in a longer bolt though.
B
H20boy
07-23-2021 09:39 PM
ym37tech
02-08-2016 01:04 PM
Shaggy9212
XJ40 ( XJ81 )
09-14-2015 08:08 PM
handcuffsready
09-07-2015 01:02 PM
JagLove86
09-06-2015 10:36 PM
Quick Reply: Front Rotor Will Not Come Off - RESOLVED
