Front shock absorber
Old Oct 3, 2022 | 02:43 PM
03platumxk8's Avatar
Default Front shock absorber
I'm looking for new front shocks for my 2003 XK8. I see the price is all over the place ($115.00/$450.00). Need some advice.
thanks DM
Old Oct 3, 2022 | 03:53 PM
Johnken's Avatar
XKR comes with adjustable shocks (very expensive). XK8 Bilstien shocks cost about $115 each. Now technically, from what I've read, one could order an XK8 with CATs (adjustable shocks) but i don't think I've ever heard of it.
Do you have a wire sticking out of/attached to the top of your shock? No? Buy the $115 shocks.
Friend measure your ride height. You may need new upper shock spacers. Height shows this. Bottom edge of wheel well to center of wheel.
As I recall front should be 15.75 inches. Look it up and verify.
John
Old Oct 3, 2022 | 06:24 PM
yostra's Avatar
The best price I found for the Bilsteins is at Rock Auto. Both fronts and Uro shock mounts ran $400, shipping and tax included.
Old Oct 4, 2022 | 07:33 AM
thanks John
DM
Old Oct 4, 2022 | 07:41 AM
thanks Ray
DM
Old Oct 4, 2022 | 08:03 AM
crvols's Avatar
I just used this combination on my 2006 and it seems to work well. Installation is another matter as getting the fajcrum bolt out was a bear.
Old Oct 4, 2022 | 02:13 PM
daro31's Avatar
The Bilstein's from Rock Auto are great but stay away from the Uro shock mounts, garbage and you will be doing the job again in 2500 miles. After the Uros's I went to Welsh and they seem very good.
Old Oct 4, 2022 | 05:02 PM
STLTHMSTA's Avatar
And the great debate begins.....glad you didn't mention oil. LOL ;^) I also used Bilsteins from RA and the URO tops. No trouble so far. Others haven't had such good luck. TM
Old Oct 4, 2022 | 07:00 PM
yostra's Avatar
One other consideration - The Bilsteins don't include bellows or bumpers. You might want to check their condition before ordering (if possible).
Old Oct 4, 2022 | 07:03 PM
STLTHMSTA's Avatar
Good point, I believe RA has those too. TM
Old Oct 5, 2022 | 08:15 AM
drmike's Avatar
John
My Y2000 XK8 has CAT shocks complete with wires. But that's an earlier car.
Old Oct 5, 2022 | 08:59 AM
jagtecuk's Avatar
If you still looking for front shockers we have some used and new instock
Old Oct 6, 2022 | 09:29 PM
giandanielxk8's Avatar
Go for the Bilsteins from Rockauto, they have the best price and those are the OE shocks. For the shock mounts, contact member cjd777, he makes an upgrade poly unit that actually has stood the test of time. I have been the guinea pig who tested the first pair and they have held up very well to Puerto Rico's hellish roads. So far, I have had them for about 1 year and 5 months with 7,000 miles, and they have outlasted the Welsh mounts and the URO mounts.
Old Oct 11, 2022 | 07:05 AM
STLTHMSTA's Avatar
I also replaced my sacked out springs with some from Lesjofors. Brought the ride height up and now I'm on he level. TM
Old Oct 11, 2022 | 03:08 PM
JayJagJay's Avatar
You don't have to remove the fulcrum bolt...
loftymk1
Apr 8, 2017 04:21 AM
Salu498
May 30, 2016 03:14 PM
gmhspot
May 25, 2015 01:15 PM
viscoussquirrel
Apr 24, 2010 10:47 PM
