Front Upper Wishbone Replacement
Old Mar 12, 2024 | 02:03 PM
Je11nsn's Avatar
Default Front Upper Wishbone Replacement
Hi All,
Bit of a newbie here but had a horrible creaking noise from the from drivers side of my 02 XKR and mechanic has informed me the osf front suspension has wear on it and require a replacement. Unfortunately Jaguar fo not seem manufacture the part anymore and i was looking for help on where to find one!
any help appreciated!
Old Mar 12, 2024 | 03:02 PM
Y2KJag's Avatar
You need to replace the entire wishbone, or just the bushings? If it's the entire wishbone did he say why?
Old Mar 12, 2024 | 03:07 PM
unless the upper wishbone is cracked or bent - the upper ball joint and bushing are EASY to replace. And even the lower ball joint/bushings (although a bit of a PITA) can be done DIY or via mechanic.
As this is your first post, please stop by the new member area and post an intro. in return, you will receive a warm welcome and useful tips to navigate the forum
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Mar 12, 2024 | 04:49 PM
baxtor's Avatar
Originally Posted by Je11nsn
Hi All,
Try and get a good pic of the suspect components and post it.
Old Mar 12, 2024 | 06:45 PM
Originally Posted by sklimii
..... the upper ball joint and bushing are EASY to replace. .....
Once you get the fulcrum bolt out.
Old Mar 15, 2024 | 05:35 AM
Spider589's Avatar
I'm in the UK and here we have a firm near to Nottingham called Autoreserve, they advertise on eBay but call them directly for much better deals - they will sell you a full reconditioned wishbone and bushes for easier replacement and if your old wishbone comes off in one piece they will give you virtually half the money back in service exchange! That's a big if, though! I ordered a fulcrum pin as well just in case but mine came out in one piece so I have a spare one now!
Old Mar 15, 2024 | 06:00 AM
For the benefit of newer members, although only forum Sponsors or Vendors may advertise their commercial services on the forum, ANY MEMBER who has received good service from a supplier can post a recommendation like this and include a link. The ONLY RESTRICTION is the member must have no connection with the business or be receiving any inducement to make the post.
With this in mind, the link to Auto Reserve Jaguar is:
https://www.autoreservejaguar.com/?gad_source=1
To be absolutely clear, I have no connection with Auto Reserve Jaguar.
Old Mar 20, 2024 | 03:45 AM
Spider589's Avatar
Thank you Graham, I have no connection with Autoreserve either, but they have been friendly and helpful to me in my hour of need!
Svalbard
Jul 31, 2022 06:27 PM
Redjags
May 29, 2022 07:24 AM
alabbasi
Dec 27, 2021 04:11 PM
Goldwing
Jun 23, 2021 01:40 AM
MaxTorq
May 24, 2021 10:25 AM
